21 Pages«<7891011>»
grappl
#81 Posted : 16 years ago
grappl
Thanks so much. I have found you and your site very helpful and have bookmarked it for future repair research. Have a wonderful day.
#82 Posted : 16 years ago
You are welcome.
buster1
#83 Posted : 16 years ago
buster1
I Am Getting A Code Of F-3 On My Ge Profile. What Does This Mean. I Have Model # Jbp79.
#84 Posted : 16 years ago
"F3" error code means the oven temperature sensor is "open". You can find the complete troubleshooting instructions on page 3 of this thread.
- The part number for the oven sensor is AP2023862
If you need the correct part number for the control board then post the complete model number of the range.
dlandis1
#85 Posted : 16 years ago
dlandis1
Hello- I'm getting an F5 error code when using the cooktop after about 30 seconds of plugging the stove in and also getting a F20 when trying to use the main oven. The double oven works fine and the cooktop works even though the F5 code is on the dials. Model PLEFMZ99EC... Any help would be awesome. Thanks
dlandis1
#86 Posted : 16 years ago
dlandis1
Nothing? Damn.. I'm waiting for the repair company to call me back as well.
#87 Posted : 16 years ago
Sorry for the delay.
The "F5" error code on the element electronic control system (ESEC) means:"A harness, mother board or user interface board has failed" while the "F20" error code shown by the Electronic Oven Control means:"Communication failure between EOC and ESEC system.
The first thing I would do in such situation is check the harness and each connection. You can find the complete instructions in the Service manual.
Here are the breakdown diagrams and Replacement parts for FRG PLEFMZ99ECA | AppliancePartsPros.com
dlandis1
#88 Posted : 15 years ago
dlandis1
Thanks Gene,
I'll start with the harness and cross my fingers.
#89 Posted : 15 years ago
Good luck and keep us posted.
tom murphy
#90 Posted : 15 years ago
tom murphy
Originally Posted by: Admin / APP Team Go to Quoted Post
Pat,
Frigidaire has recently come out with new error codes, including F13. We'll update our code page shortly.
F13 stands for "Bad EEPROM Identification/Checksum error". If power cycling does not help, replace the electronic oven control. You can enter your oven model number here http://www.appliancepartspros.com/partsearch/ and see price and availability for the control.
Hope this helps.
Do you happen to know F30 error code for fridgidaire oven/range? Stovetop works/ oven creates code, digital clock dim.
Thanks, Tom
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9 years ago
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 12 years ago
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 12 years ago
by fred jacoby 13 years ago
by sigman 13 years ago
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 13 years ago
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 14 years ago
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 15 years ago
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 15 years ago
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 16 years ago
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 16 years ago
by cndybkr 16 years ago
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 17 years ago
21 Pages«<7891011>»
