Thanks so much. I have found you and your site very helpful and have bookmarked it for future repair research. Have a wonderful day.
I Am Getting A Code Of F-3 On My Ge Profile. What Does This Mean. I Have Model # Jbp79.
Originally Posted by: buster1  I Am Getting A Code Of F-3 On My Ge Profile. What Does This Mean. I Have Model # Jbp79. "F3" error code means the oven temperature sensor is "open". You can find the complete troubleshooting instructions on page 3 of this thread. - The part number for the oven sensor is AP2023862 If you need the correct part number for the control board then post the complete model number of the range. Gene.
Hello- I'm getting an F5 error code when using the cooktop after about 30 seconds of plugging the stove in and also getting a F20 when trying to use the main oven. The double oven works fine and the cooktop works even though the F5 code is on the dials. Model PLEFMZ99EC... Any help would be awesome. Thanks
Nothing? Damn.. I'm waiting for the repair company to call me back as well.
Sorry for the delay. The "F5" error code on the element electronic control system (ESEC) means:"A harness, mother board or user interface board has failed" while the "F20" error code shown by the Electronic Oven Control means:"Communication failure between EOC and ESEC system. The first thing I would do in such situation is check the harness and each connection. You can find the complete instructions in the Service manual. Here are the breakdown diagrams and Replacement parts for FRG PLEFMZ99ECA | AppliancePartsPros.comGene.
Thanks Gene,
I'll start with the harness and cross my fingers.
Good luck and keep us posted.
Originally Posted by: Admin / APP Team  Pat, Frigidaire has recently come out with new error codes, including F13. We'll update our code page shortly. F13 stands for "Bad EEPROM Identification/Checksum error". If power cycling does not help, replace the electronic oven control. You can enter your oven model number here http://www.appliancepartspros.com/partsearch/ and see price and availability for the control. Hope this helps. Do you happen to know F30 error code for fridgidaire oven/range? Stovetop works/ oven creates code, digital clock dim. Thanks, Tom
