stokeral
#1 Posted : Monday, November 4, 2013 1:19:48 PM(UTC)
stokeral
My dryer will ignite and after about 10 seconds will turn off. The air flow passages are as clean as the day it came out of the factory. I have replaced the High Limit Thermostat, the cycling thermostat and the two gas valve coils...Can anyone please help....Alan
HumboldtRepairMan
#2 Posted : Monday, November 4, 2013 4:42:19 PM(UTC)
HumboldtRepairMan
These units are prone to bad timers or bad connections at the timers check your connections and wiring from your timers down to your ignitor and that complete circuit check your voltage going down to your ignitor should be 120v and test the unit for 20-30 minutes and your ignitor ohms should be 0-50 ohms. Check your tech sheet for the wires you need to test. Pop the port open in the front to see if your ignitor is glowing. If it's glowing every single time and it's not releasing gas you may have a gas valve faulty also.
http://www.youtube.com/watch?v=Q8j6fQM3P34
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
