TVJ
#1 Posted : Tuesday, December 11, 2007 5:11:05 AM(UTC)
TVJ
I Had A Repair Man To Come And He Told Me That It Was The Agitator Dog. Need To To Know How To Correct This Problem.
Thanks Tvj
TVJ
#2 Posted : Tuesday, December 11, 2007 5:15:14 AM(UTC)
TVJ
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
TVJ
#3 Posted : Tuesday, December 11, 2007 5:21:22 AM(UTC)
TVJ
Please Send Reply
#4 Posted : Tuesday, December 11, 2007 2:27:07 PM(UTC)
You can find it in one of my previous posts: http://forum.appliancepartspros...eries-not-agitating.html
cellis3
#5 Posted : Friday, December 14, 2007 11:47:35 PM(UTC)
cellis3
washer won't agitate or spin . I don't know if it will draind because the water is already drained out. I have a 10 year old Whirlpool
Model Number LST7233DQO
#6 Posted : Monday, December 17, 2007 9:14:24 AM(UTC)
Most likely the problem with your washer is a bad motor drive coupling (#13 on the break, clutch, gear case, motor and pump break down diagram).
- The part number for the motor drive coupling is AP3963893
Guest (6)
Kenmore Washer will not agitate, but it will spin (Washer Repair)
by mjaymadson 8/2/2022 9:37:22 PM(UTC)
Estate washer will not agitate properly (Washer Repair)
by Guest 4/21/2022 8:19:49 AM(UTC)
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
kenmore washer will not agitate (Washer Repair)
by crawdadcreek 7/29/2015 10:07:27 AM(UTC)
by lizardking508 6/21/2015 12:00:22 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
Washer will not agitate (Washer Repair)
by jemiller33 11/25/2014 4:02:02 PM(UTC)
Washer will not agitate, or spin (Washer Repair)
by win809doo 5/19/2014 8:19:45 AM(UTC)
Washer will not agitate, spin, or drain (Washer Repair)
by nosinina 4/16/2014 8:42:37 AM(UTC)
Washer will not agitate, but does spin. (Washer Repair)
by Kas23 3/18/2014 2:50:05 PM(UTC)
washer will not agitate or spin (Washer Repair)
by CHERIE KING 2/27/2014 8:16:38 AM(UTC)
by dan mayville 12/23/2013 1:52:45 PM(UTC)
GE washer will not agitate but will rinse and spin (Washer Repair)
by gabemich 11/20/2013 8:35:25 AM(UTC)
Washer will not agitate spin or drain (Washer Repair)
by mdbk 11/6/2013 7:49:14 PM(UTC)
