Discuss
Kenmore 80's series not agitating
 in
Washer Repair
My Kenmore washer does not seem to agitate properly. It will occasionally go around, but has a vibration to it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 80's series not agitating
  #1 (permalink)
Old 08-07-2007, 01:38 PM
Junior Member
leothedog is on a distinguished road
Default Kenmore 80's series not agitating
Model Number: 110 20892 990   Brand: Kenmore   Age: 5 - 10 years
My Kenmore washer does not seem to agitate properly. It will occasionally go around, but has a vibration to it and does not pull the clothing down. I don't know if something is loose or stripped. I can spin it freely, but don't know if this is a good thing or a bad thing.
If this is something I can fix great, but I need to know what is wrong first and how to do it. If I need to call a repair tech, is it a costly item and would it just be better to buy new as it is about 8 years old.
Ads By Google
Related Models
Kenmore 110.0  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.088732791  WASHER/DRYER LAUNDRY SYSTEM
Kenmore 110.1  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.10202000  COMPACT WASHER
Kenmore 110.10202001  WASHER
Kenmore 110.10502990  AUTOMATIC WASHER
Kenmore 110.10502991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.10852990  AUTOMATIC WASHER
Kenmore 110.10852991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12202100  WASHER
Kenmore 110.12502100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12852100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.13202200  WASHER
Kenmore 110.13212200  AUTOMATIC WASHER
Kenmore 110.14212200  AUTOMATIC WASHER
Kenmore 110.16101690  AUTOMATIC WASHER
Kenmore 110.16101691  AUTOMATIC WASHER
Kenmore 110.16202690  WASHER
Sears 110.16202691  AUTOMATIC WASHER
Kenmore 110.16502690  WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.16512690  WASHER
Kenmore 110.18202790  AUTOMATIC WASHER
Kenmore 110.18522790  AUTOMATIC WASHER
Kenmore 110.18522791  AUTOMATIC WASHER
Kenmore 110.18532790  AUTOMATIC WASHER
Kenmore 110.18542891  AUTOMATIC WASHER
Kenmore 110.18609890  AUTOMATIC WASHER
Kenmore 110.18702790  AUTOMATIC WASHER
Kenmore 110.18702791  AUTOMATIC WASHER
Kenmore 110.19101990  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101991  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101992  WASHER
Kenmore 110.19202200  AUTOMATIC WASHER-GALAXY
Kenmore 110.19422200  AUTOMATIC WASHER-GALAXY
Kenmore 110.20052991  WASHER
Kenmore 110.20052992  WASHER
Kenmore 110.20052993  AUTOMATIC WASHER
Kenmore 110.20056993  AUTOMATIC WASHER
Kenmore 110.20112000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.2011200A  WASHER
Kenmore 110.20132000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20132001  WASHER
Kenmore 110.20172000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20172001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.20272000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20272001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
  #2 (permalink)
Old 08-10-2007, 10:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
leothedog
Does your washer spin properly? Does it drain? I need as much information as possible.
  #3 (permalink)
Old 08-17-2007, 04:01 PM
Junior Member
Default
Everything esle works just fine.. Spins, takes water, and drains. I do not see any other issues with it at this time..
  #4 (permalink)
Old 08-18-2007, 04:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
leothedog
The agitator in your washer consists of two parts: the base and the top part. My question is: the top part of the agitator moves freely in both directions while the base is not moving or the top part moves only clockwise freely?
If it moves freely in both directions then the cam dogs have to be replaced.
You should use the agitator repair kit, part number AP3138838.
On the break down diagram bellow you can see the sequence of the agitator part:
Good luck.
  #5 (permalink)
Old 08-23-2007, 09:36 PM
Junior Member
Default
Thanks, sorry for the late response, out of town..
  #6 (permalink)
Old 04-29-2009, 09:03 PM
Junior Member
dstrong is on a distinguished road
Default I have the same issue with the same model number.
I am looking for some instructions on how to replace the kit mentioned in the previous posts. I have ordered it and the grease, but I have no clue where to even start to take this apart. Can anyone offer suggestions or lead me to a place to find a book on this? I have searched the internet and am finding very little for this model #. Sears parts site says it is not a valid model #. Go figure.
-David
  #7 (permalink)
Old 04-30-2009, 09:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
David,
Remove the softener dispenser and the agitator cap. Unscrew the bolt.
You also can find these two video clips: YouTube - Kenmore Series 80 Model 110 top agitator fix! and YouTube - How to fix your Kenmore Series 80 Model 110 agitator part 3 helpful.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #8 (permalink)
Old 08-23-2010, 07:36 AM
Junior Member
Tripp is on a distinguished road
Default
Gene,
I seem to be having the same problem but wanted to make sure. When I press down on the agitator assembly when it is in the agitating cycle, it seems to grab as it should however, will not rotate 360 degrees unless I spin it by hand. Does this sound like it could be the dogs also?
  #9 (permalink)
Old 08-23-2010, 02:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Tripp View Post
Gene,
What is the complete model number of your washer?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore 80 series washer not agitating david.graham Washer Repair 4 02-26-2010 12:30 PM
Kennmore 80 Series not agitating or spinning Bec Bec Washer Repair 1 12-31-2008 06:12 AM
portable kenmore tub turns while agitating Lisan Washer Repair 1 11-05-2008 05:14 PM
kenmore not agitating bontree Washer Repair 5 06-19-2008 11:30 AM
kenmore not agitating bontree Washer Repair 1 04-11-2008 03:08 PM
