gtmarcelo
#1 Posted : Tuesday, April 16, 2013 4:10:07 PM(UTC)
gtmarcelo
No heating in the dryer. Heating element has broken element. Tested with ohm meter and no continuity in the terminal connections. This element needs to be replaced. The problem is how to take out element from the heater housing ? confused:
#2 Posted : Wednesday, April 17, 2013 4:30:13 PM(UTC)
Hello,
You have to remove the heater box first.
Remove the rear cover. Remove the screw that secures the strap spring at the top of the box. Remove the wire leads to the hi-limit thermostat and the heat element. Lift the box off its supports. remove one retaining screw at the bottom of the heater box. Pull the element out through the bottom of the heater box.
In order to install the new elemnt you may need two additional connecting wires which should be ordered separately.
- The heating element Part number: 4391960
- The connecting wire Part number: 279457
Part number: 279457
gtmarcelo
#3 Posted : Thursday, April 18, 2013 9:16:05 AM(UTC)
gtmarcelo
Gene,
Thank you so much to my question. This is very helpfull and make my life easier to fix my dryer. Although this dryer is 23 years old it still give good service. Gene you are a very good man. Again thank you so much. :) :)
Gil Marcelo
#4 Posted : Thursday, April 18, 2013 10:44:59 AM(UTC)
You are welcome Gil. Thank you for your good words. Keep us posted.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
