pmclaughlin@apins.com
#1 Posted : Tuesday, April 9, 2013 11:18:38 AM(UTC)
I have a fairly new Whirlpool dryer. It just quit working. I've already replaced the timer and start button. Still not working. It's not the plug in as we plugged the dryer into another plug. Still not working. Does anyone have any further ideas? (I just purchased a door switch and am waiting on the delivery to see if that is what the problem is)
Simon / APP Team
#2 Posted : Tuesday, April 9, 2013 11:37:30 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Need to have the model number. Open the door and look for a tag around the opening or the door itself.
Post the results.
Simon.
#3 Posted : Tuesday, April 9, 2013 12:20:29 PM(UTC)
It is a Whirlpool #WED5300SQ0
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
Simon / APP Team
#4 Posted : Tuesday, April 9, 2013 1:36:17 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the cover of the dryer's back and check the thermal fuse
Part number: AP3132867
for continuity. If you don't have a meter install the temporary jumper across the fuse (unplug the dryer first).
If it's the fuse - replace it and check the entire air flow system for clogs.
Here are breakdown diagrams and Bulkhead parts for Whirlpool WED5300SQ0 - AppliancePartsPros.com
Post the results.
Simon.
Guest (4)
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Dryer WOn't Run (Dryer Repair)
by wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
dryer won't run (Dryer Repair)
by dymetz62 1/8/2014 5:00:20 PM(UTC)
by Ronald Walls 3/19/2013 1:09:09 PM(UTC)
by Ronald Walls 3/19/2013 1:06:28 PM(UTC)
by loumemoli 7/2/2012 1:33:54 PM(UTC)
dryer won't run but heats up fast (Dryer Repair)
by w. carroll 3/28/2012 8:22:26 AM(UTC)
Dryer Won't Run (Dryer Repair)
by paul888 1/16/2012 1:37:57 PM(UTC)
Dryer won't run after start. (Dryer Repair)
by clparks 4/28/2011 9:49:25 AM(UTC)
by tterry 3/29/2011 10:49:47 AM(UTC)
by DarrelD 1/31/2011 1:09:02 PM(UTC)
