neilgb
#1 Posted : Thursday, March 21, 2013 9:33:07 AM(UTC)
neilgb
Washer is cycling however spray arms are not turning. I read that by adding Dishwasher Magic might solve this. Any ideas?
#2 Posted : Thursday, March 21, 2013 3:33:36 PM(UTC)
Are all spray arms not turning?
How much water is inside the dishwasher when it is on the wash cycle?
What is the end of the model number?
neilgb
#3 Posted : Thursday, March 28, 2013 9:24:08 AM(UTC)
neilgb
Gene,
Both arms are not turning. I have cleaned all jets. There is less than an inch of water. The water is below the heating element.
Model number is GU1500XTLSO
#4 Posted : Thursday, March 28, 2013 1:46:33 PM(UTC)
Very likely the problem is a clogged/bad chopper (#6 at the diagram). You can find more information in one of our previous threads: [FONT=&quot]http://forum.appliancepartspros...hirlpool-dishwasher.html
- The chopper
[/FONT]Part number: 8268383
Here are the breakdown diagrams and Parts for Whirlpool GU1500XTLS0 Dishwasher - AppliancePartsPros.com
P.S. The normal amount of water should be about 1.8 gallons
neilgb
#5 Posted : Thursday, March 28, 2013 2:09:33 PM(UTC)
neilgb
Thanks for the information. How do I access that part? Do you think it might be the water inlet valve?
#6 Posted: : Thursday, March 28, 2013 2:11:43 PM(UTC)
The first thing I would do is check the chopper. Click on the link I posted to read the instructions.
neilgb
#7 Posted : Friday, March 29, 2013 11:23:21 AM(UTC)
neilgb
Gene,
I removed the chopper and don't see anything wrong with it. Is there something in particular to look for?
#8 Posted : Friday, March 29, 2013 4:13:14 PM(UTC)
If the chopper is clean and engages the motor impeller properly then there is nothing wrong with it.
The next step is to verify proper amount of water. Open the dishwasher door wile it's in wash cycle. Manually add a few caps of water and check movement of the spray arms.
If you'll see the improvement, replace the water inlet valve.
- The water inlet valve Part number: 8531670
neilgb
#9 Posted : Wednesday, April 3, 2013 11:32:23 AM(UTC)
neilgb
Gene,
Now it is filling with water and then hums rather than starting wash cycle. After a few minutes it discharges, So do you still think it s the water inlet valve or maybe the float switch?
#10 Posted : Wednesday, April 3, 2013 4:57:23 PM(UTC)
Remove the bottom access panel and pinpoint that humming sound.
Dishwasher Spray Arms Not Spinning / Not Enough Water [SOLVED] (Dishwasher Repair)
by MontyTWD 10/5/2020 8:05:23 PM(UTC)
KitchenAid KUDS30IXBLA Dishwasher Upper Spray Arms Not Spinning (Dishwasher Repair)
by navagator 8/24/2019 11:58:55 PM(UTC)
Bosch/Gaggeneau Low pressure from spray arms - tried everything (Dishwasher Repair)
by fixitboy 7/27/2019 10:50:29 PM(UTC)
No pressure in spray arms (Dishwasher Repair)
by Doop007 9/4/2015 7:21:56 AM(UTC)
GE Monogram Dishwasher-Rubbery particles clogging spray arms (Dishwasher Repair)
by BigJimmyJ 4/8/2014 7:33:54 AM(UTC)
dishwasher spray arms wont spin (Dishwasher Repair)
by danao 12/9/2013 10:01:01 AM(UTC)
Frigidaire Spray arms not moving or getting water (Dishwasher Repair)
by dharris89 12/2/2013 8:35:54 AM(UTC)
Bosch spray arms not spinning (Dishwasher Repair)
by dpw-ct 7/4/2013 7:14:58 AM(UTC)
spray arms idle (Dishwasher Repair)
by Toddagod 12/9/2012 10:15:37 AM(UTC)
Spray arms for GE dishwasher constantly clogging (Dishwasher Repair)
by brindlebaby 11/11/2012 5:20:29 PM(UTC)
Bosch DW spray arms not turning (Dishwasher Repair)
by Max Headroom 8/28/2012 2:10:24 PM(UTC)
doesn't have enough water to turn spray arms (Dishwasher Repair)
by ELETT1 7/9/2012 6:12:24 PM(UTC)
Want to remove spray arms to clean (Dishwasher Repair)
by Ime 4/29/2012 4:33:30 PM(UTC)
LG Spray arms not working (Dishwasher Repair)
by nickdef1 4/19/2011 9:39:46 AM(UTC)
Spray arms don't spin/hard water build up (Dishwasher Repair)
by rzq6c8 2/20/2011 4:29:09 PM(UTC)
