neilgb
#1 Posted : 12 years ago
neilgb
Washer is cycling however spray arms are not turning. I read that by adding Dishwasher Magic might solve this. Any ideas?
#2 Posted : 12 years ago
Are all spray arms not turning?
How much water is inside the dishwasher when it is on the wash cycle?
What is the end of the model number?
neilgb
#3 Posted : 12 years ago
neilgb
Gene,
Both arms are not turning. I have cleaned all jets. There is less than an inch of water. The water is below the heating element.
Model number is GU1500XTLSO
#4 Posted : 12 years ago
Very likely the problem is a clogged/bad chopper (#6 at the diagram). You can find more information in one of our previous threads: [FONT=&quot]http://forum.appliancepartspros...hirlpool-dishwasher.html
- The chopper
[/FONT]Part number: 8268383
Here are the breakdown diagrams and Parts for Whirlpool GU1500XTLS0 Dishwasher - AppliancePartsPros.com
P.S. The normal amount of water should be about 1.8 gallons
neilgb
#5 Posted : 12 years ago
neilgb
Thanks for the information. How do I access that part? Do you think it might be the water inlet valve?
#6 Posted : 12 years ago
The first thing I would do is check the chopper. Click on the link I posted to read the instructions.
neilgb
#7 Posted : 12 years ago
neilgb
Gene,
I removed the chopper and don't see anything wrong with it. Is there something in particular to look for?
#8 Posted : 12 years ago
If the chopper is clean and engages the motor impeller properly then there is nothing wrong with it.
The next step is to verify proper amount of water. Open the dishwasher door wile it's in wash cycle. Manually add a few caps of water and check movement of the spray arms.
If you'll see the improvement, replace the water inlet valve.
- The water inlet valve Part number: 8531670
neilgb
#9 Posted : 12 years ago
neilgb
Gene,
Now it is filling with water and then hums rather than starting wash cycle. After a few minutes it discharges, So do you still think it s the water inlet valve or maybe the float switch?
#10 Posted : 12 years ago
Remove the bottom access panel and pinpoint that humming sound.
Dishwasher Spray Arms Not Spinning / Not Enough Water [SOLVED] (Dishwasher Repair)
by MontyTWD 4 years ago
KitchenAid KUDS30IXBLA Dishwasher Upper Spray Arms Not Spinning (Dishwasher Repair)
by navagator 6 years ago
Bosch/Gaggeneau Low pressure from spray arms - tried everything (Dishwasher Repair)
by fixitboy 6 years ago
No pressure in spray arms (Dishwasher Repair)
by Doop007 10 years ago
GE Monogram Dishwasher-Rubbery particles clogging spray arms (Dishwasher Repair)
by BigJimmyJ 11 years ago
dishwasher spray arms wont spin (Dishwasher Repair)
by danao 11 years ago
Frigidaire Spray arms not moving or getting water (Dishwasher Repair)
by dharris89 11 years ago
Bosch spray arms not spinning (Dishwasher Repair)
by dpw-ct 12 years ago
spray arms idle (Dishwasher Repair)
by Toddagod 12 years ago
Spray arms for GE dishwasher constantly clogging (Dishwasher Repair)
by brindlebaby 12 years ago
Bosch DW spray arms not turning (Dishwasher Repair)
by Max Headroom 13 years ago
doesn't have enough water to turn spray arms (Dishwasher Repair)
by ELETT1 13 years ago
Want to remove spray arms to clean (Dishwasher Repair)
by Ime 13 years ago
LG Spray arms not working (Dishwasher Repair)
by nickdef1 14 years ago
Spray arms don't spin/hard water build up (Dishwasher Repair)
by rzq6c8 14 years ago
