albert brodeur
#1 Posted : Friday, March 13, 2009 4:02:27 PM(UTC)
albert brodeur
Gentlemen,
this dryer ,s control panel will light up and go off by itself. and it will not always do this sometimes it will stay off like it should and then other times it off and on only the control panel lights up the dryer drums does not turn or heat but it will if the stsart button is pushed everything looks ok no corrison that is visable the power switch on the user interface board checked ok
I do not have a schematic of the interface board or the machine control board
P/N's of the boards machine control board is 3978982
Interface board is 8564376
which of these devils is the bad guy?
thank you
al brodeur
#2 Posted : Saturday, March 14, 2009 3:04:26 AM(UTC)
These should help narrow it down
https://www.servicematters.com/d...heet%20-%20W10035270.pdf
https://www.servicematters.com/d...0Sheet%20-%203978975.pdf
Sounds like a bad connection somewhere, probably going to be a royal pain to find.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
albert brodeur
#3 Posted : Saturday, March 14, 2009 10:30:57 AM(UTC)
albert brodeur
I have done all of that using contact cleaner and the pencil eraser but later I swapped the power switch with another cycle one and it has worked so far
what bogels the mind is that power comes into a normaly closed switch yet by pressing it the unit turns on
#4 Posted : Saturday, March 14, 2009 1:25:08 PM(UTC)
Do not know what power switch you are referring to so cannot comment.
I guess don't argue with success applies!!!
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
