Jim
jetoan123
#1 Posted : Friday, March 16, 2012 6:17:59 PM(UTC)
jetoan123
I have the dryer apart and assume that the coiled wires on the rear is the heating element. 2 of the wires look to be broken. The dryer runs and will not heat. I have checked the 3 thermostats and they are ok. If this is the heating element does it sound like I would need to replace it
#2 Posted : Saturday, March 17, 2012 4:26:01 AM(UTC)
Replacement parts for General Electric DCLR333ET1WW Electric dryer | AppliancePartsPros.com
The heating element is Item 512 in Section 4.
Click on it's picture for more/better views and info.
Yes if the coils are broken the heater will have to be replaced.
Since you have to pull it apart I would check other parts, might as well give it an overhaul.
Also this will give you an idea of what the full repair will cost. It may not be worth repairing,
Check the belt, drum seals, front drum glides, rear support bearing internal air flow seals etc.
Jenn-Air JIM158XBRS2 freestanding ice maker HELP! (Refrigerator & Freezer Repair)
by DaveRicciuti 6/11/2019 12:18:15 PM(UTC)
jim123 (Washer Repair)
by jim 123 3/26/2015 12:59:17 PM(UTC)
Jimmy T. (Dryer Repair)
by Jimmy T. 7/27/2013 5:41:06 PM(UTC)
Jimkeyes (Refrigerator & Freezer Repair)
by JimKeyes 10/3/2012 1:06:39 PM(UTC)
jim (Refrigerator & Freezer Repair)
by jim baird 7/12/2012 11:40:58 AM(UTC)
Jim (Washer Repair)
by Jimm1 4/17/2012 6:04:21 PM(UTC)
jim b56 (Oven Repair (including Ranges and Cooktops))
by jim b56 2/12/2012 8:51:37 AM(UTC)
jim Colucy (Washer Repair)
by Jim Colucy 9/4/2010 9:23:51 AM(UTC)
Jim E (Refrigerator & Freezer Repair)
by jim eckart 8/26/2010 11:28:36 AM(UTC)
by jim eckart 8/19/2010 4:59:14 PM(UTC)
by jim crane 8/16/2010 3:59:48 PM(UTC)
Jim Kennedy (Oven Repair (including Ranges and Cooktops))
by Jim Kennedy 1/6/2010 11:44:01 AM(UTC)
by Jim Kennedy 1/6/2010 11:41:53 AM(UTC)
jimmyb (Dryer Repair)
by jbradford 11/24/2009 6:07:56 PM(UTC)
jimmy (Washer Repair)
by jwhite22 9/21/2009 8:11:57 AM(UTC)
