My dryer will not stop when the cycle is up or get hot. It will go on to the next cycle. I change the fuse. What else should I check or do?:(
Would it stop if you open the door?
Would it restart by itself as soon as you close the door?
Originally Posted by: richelle My dryer will not stop when the cycle is up or get hot. It will go on to the next cycle. I change the fuse. What else should I check or do?:( If the timer passes the off cycle, and continues it is most likely the timer. Tom ApplianceEducator.com
