2 Pages<12
magician59
#11 Posted : Wednesday, November 19, 2008 3:24:06 PM(UTC)
magician59
If you can read a Schematic, you'll find one in the console. I couldn't pull one up for your model #. Just look for the specific motor-related wires coming off the timer and check those contacts with your volt meter. That'll tell you if power is leaving the timer.
dveljko
#12 Posted : Wednesday, November 19, 2008 7:03:07 PM(UTC)
dveljko
I checked wireing and there is a power to the motor. Does this motor have some kind of overload switch that need to be reset.
dveljko
#13 Posted : Thursday, November 20, 2008 5:39:02 AM(UTC)
dveljko
Magician59 thak you for all your help. I was able to find drawing and after tracing evrything, I found problem. The problem is inside the motor. The centrifugal switch is loosing connection and it is not letting motor start. Unfortunatly, motor can not be taken apart so I may just buy new washer instead of putting money in old machine.
magician59
#14 Posted : Thursday, November 20, 2008 10:11:32 AM(UTC)
magician59
Well done! Honestly, though, no matter what anyone else says; If your machine doesn't leak or roar (indicating bearing failure), I would spend the money for a replacement motor. Dependable Care machines are truly dependable.
Kenmore Washer will not agitate, but it will spin (Washer Repair)
by mjaymadson 8/2/2022 9:37:22 PM(UTC)
Estate washer will not agitate properly (Washer Repair)
by Guest 4/21/2022 8:19:49 AM(UTC)
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
kenmore washer will not agitate (Washer Repair)
by crawdadcreek 7/29/2015 10:07:27 AM(UTC)
by lizardking508 6/21/2015 12:00:22 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
Washer will not agitate (Washer Repair)
by jemiller33 11/25/2014 4:02:02 PM(UTC)
Washer will not agitate, or spin (Washer Repair)
by win809doo 5/19/2014 8:19:45 AM(UTC)
Washer will not agitate, spin, or drain (Washer Repair)
by nosinina 4/16/2014 8:42:37 AM(UTC)
Washer will not agitate, but does spin. (Washer Repair)
by Kas23 3/18/2014 2:50:05 PM(UTC)
washer will not agitate or spin (Washer Repair)
by CHERIE KING 2/27/2014 8:16:38 AM(UTC)
by dan mayville 12/23/2013 1:52:45 PM(UTC)
GE washer will not agitate but will rinse and spin (Washer Repair)
by gabemich 11/20/2013 8:35:25 AM(UTC)
Washer will not agitate spin or drain (Washer Repair)
by mdbk 11/6/2013 7:49:14 PM(UTC)
2 Pages<12
