2 Pages12>
dveljko
#1 Posted : Wednesday, November 19, 2008 6:49:10 AM(UTC)
dveljko
First thing I found when I opened front control panel was that small glass fuse was burned. I replaced fuse and machine started to fill water. Once water level was reched, water valve closed and nothing happened till timer reached last spin and pumped water out.
magician59
#2 Posted : Wednesday, November 19, 2008 7:50:20 AM(UTC)
magician59
Did it spin, or just pump out? Did you hear motor noise? Check for broken belt(s).
Emmett Talley
#3 Posted : Wednesday, November 19, 2008 7:57:49 AM(UTC)
Emmett Talley
it didnt spin
Emmett Talley
#4 Posted : Wednesday, November 19, 2008 7:59:10 AM(UTC)
Emmett Talley
it didnt spin in the spin cycle
Emmett Talley
#5 Posted : Wednesday, November 19, 2008 8:03:07 AM(UTC)
Emmett Talley
:confused:
dveljko
#6 Posted : Wednesday, November 19, 2008 9:36:51 AM(UTC)
dveljko
It did spin when pump was pumping water out.
magician59
#7 Posted : Wednesday, November 19, 2008 10:07:43 AM(UTC)
magician59
Could be (from least expensive to most expensive):Worn or broken belts; Bad lid switch assembly; Bad Timer; Bad motor; Bad transmission.
dveljko
#8 Posted : Wednesday, November 19, 2008 10:16:12 AM(UTC)
dveljko
I eleiminated belts and motor since motor was spining and pumping and water out. This motor have two belts one for wash and one for pump. After water level reched set level, machine did not made any noise besides timer running. Timer passed first rince and did not pump water out. It was just turning (without motor agitating or making any noise) till reached the point when needed to spin and drain water. When it was spining i opened the lid and motor stoped. I closed the lid and machine finished spining and pumping water out.
magician59
#9 Posted : Wednesday, November 19, 2008 11:11:28 AM(UTC)
magician59
That eliminates the lid switch and the motor. Possible bad timer or bad transmission. Timers fail more often and cost quite a bit less. If you're handy with hand tools, replacing the timer is well within your ability.
dveljko
#10 Posted : Wednesday, November 19, 2008 1:25:50 PM(UTC)
dveljko
I was going to check timer to see if it is sending connection to the motor. Do you know what pins should have connection when machnine is washing (agitating)
Kenmore Washer will not agitate, but it will spin (Washer Repair)
by mjaymadson 8/2/2022 9:37:22 PM(UTC)
Estate washer will not agitate properly (Washer Repair)
by Guest 4/21/2022 8:19:49 AM(UTC)
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
kenmore washer will not agitate (Washer Repair)
by crawdadcreek 7/29/2015 10:07:27 AM(UTC)
by lizardking508 6/21/2015 12:00:22 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
Washer will not agitate (Washer Repair)
by jemiller33 11/25/2014 4:02:02 PM(UTC)
Washer will not agitate, or spin (Washer Repair)
by win809doo 5/19/2014 8:19:45 AM(UTC)
Washer will not agitate, spin, or drain (Washer Repair)
by nosinina 4/16/2014 8:42:37 AM(UTC)
Washer will not agitate, but does spin. (Washer Repair)
by Kas23 3/18/2014 2:50:05 PM(UTC)
washer will not agitate or spin (Washer Repair)
by CHERIE KING 2/27/2014 8:16:38 AM(UTC)
by dan mayville 12/23/2013 1:52:45 PM(UTC)
GE washer will not agitate but will rinse and spin (Washer Repair)
by gabemich 11/20/2013 8:35:25 AM(UTC)
Washer will not agitate spin or drain (Washer Repair)
by mdbk 11/6/2013 7:49:14 PM(UTC)
2 Pages12>
