kfrith
#1 Posted : Monday, November 17, 2008 8:52:02 AM(UTC)
kfrith
My refigerator is leaking from the freezer into the fridge below. This is not a constant leak but periodically happens and eventually water builds up on the bottom of the fridge. I can sometimes see the water dripping and I noticed one time it was coming out quite a lot from the feezer and then eventually stopped. The vents are clear.
Any ideas?
Thanks,
Ken
#2 Posted : Tuesday, November 18, 2008 1:12:04 PM(UTC)
Hi Ken,
The cause of this problem is a frozen drain in the freezer. Remove the freezer floor and the rear panel. The drain hole is under the evaporator coil on the back of the freezer. You can use a hair dryer do defrost it.
Here are the break down diagrams for the Whirlpool refrigerator Model ET8CHKXKB02
kfrith
#3 Posted : Tuesday, November 18, 2008 1:56:15 PM(UTC)
kfrith
Thanks Gene.
I am not much of a handyman. Would you advise bringing in a repairman to do this? It looks like it may be complicated to take apart after looking at your diagrams.
Thanks again,
Ken
#4 Posted : Tuesday, November 18, 2008 2:10:06 PM(UTC)
Of course you can but be careful and do not let them to rip you off. This job should not be very expensive.
GE GSHS9NGYBCSS Refrigerator Leaking and Not Cooling (Refrigerator & Freezer Repair)
by Wudman 1/13/2023 5:12:29 AM(UTC)
Refrigerator leaking after drain line is replaced. (Refrigerator & Freezer Repair)
by JustLooking72 9/22/2020 4:12:05 PM(UTC)
Refrigerator Leaking on the ice tray and front door (Refrigerator & Freezer Repair)
by RobertoS 8/2/2020 9:55:52 AM(UTC)
Whirlpool refrigerator leaks water (Refrigerator & Freezer Repair)
by timba 2/2/2020 2:09:49 PM(UTC)
Refrigerator Leaking inside (Refrigerator & Freezer Repair)
by iconracr 11/22/2019 8:15:56 AM(UTC)
GE Refrigerator leaks water (Refrigerator & Freezer Repair)
by low_lead 7/30/2015 2:04:37 PM(UTC)
GE refrigerator leaking water from bottom (Refrigerator & Freezer Repair)
by Raidem8 5/19/2015 10:50:03 AM(UTC)
Samsung Refrigerator leaking inside bottom of fridge area (Refrigerator & Freezer Repair)
by dpointer68 4/28/2014 7:03:27 PM(UTC)
Whirlpool refrigerator leaking water (Refrigerator & Freezer Repair)
by goosemasterkl 1/1/2014 8:14:42 AM(UTC)
Samsung refrigerator leaking water (Refrigerator & Freezer Repair)
by wendyjoe 5/27/2013 8:57:36 AM(UTC)
Samsung refrigerator leaking water on fresh food side (Refrigerator & Freezer Repair)
by TWAppliance 2/10/2013 11:16:13 AM(UTC)
Refrigerator leak (Refrigerator & Freezer Repair)
by gppaul 1/27/2013 5:08:52 PM(UTC)
Refrigerator leaking (Refrigerator & Freezer Repair)
by TomFrykman 1/22/2013 1:29:54 PM(UTC)
Refrigerator leaking on floor (Refrigerator & Freezer Repair)
by Qapla 12/31/2012 4:38:59 AM(UTC)
Kenmore refrigerator leaking (Refrigerator & Freezer Repair)
by rosesbjs 11/11/2012 11:11:53 PM(UTC)
