Raidem8
#1 Posted : Tuesday, May 19, 2015 10:50:03 AM(UTC)
Raidem8
My GE refrigerator is leaking water from the bottom of it. I put hot water into the drain in the freezer section, but it is still leaking. Could the drain tube still be clogged with something other than ice.
It usually takes 3 or 4 days for the water to show up by the bottom of the fridge, but there is always water underneath it.
Raidem8
#2 Posted : Saturday, June 13, 2015 12:30:09 PM(UTC)
Raidem8
Ok, I found the leak. The water storage line has a hole in it right were it connects to the water inlet valve. When you access the water dispenser, water shoots out of the water line onto the floor. :)
