kfrith
#1 Posted : Monday, November 17, 2008 8:52:02 AM(UTC)
kfrith
My refigerator is leaking from the freezer into the fridge below. This is not a constant leak but periodically happens and eventually water builds up on the bottom of the fridge. I can sometimes see the water dripping and I noticed one time it was coming out quite a lot from the feezer and then eventually stopped. The vents are clear.
Any ideas?
Thanks,
Ken
#2 Posted : Tuesday, November 18, 2008 1:12:04 PM(UTC)
Hi Ken,
The cause of this problem is a frozen drain in the freezer. Remove the freezer floor and the rear panel. The drain hole is under the evaporator coil on the back of the freezer. You can use a hair dryer do defrost it.
Here are the break down diagrams for the Whirlpool refrigerator Model ET8CHKXKB02
kfrith
#3 Posted : Tuesday, November 18, 2008 1:56:15 PM(UTC)
kfrith
Thanks Gene.
I am not much of a handyman. Would you advise bringing in a repairman to do this? It looks like it may be complicated to take apart after looking at your diagrams.
Thanks again,
Ken
#4 Posted : Tuesday, November 18, 2008 2:10:06 PM(UTC)
Of course you can but be careful and do not let them to rip you off. This job should not be very expensive.
Guest (4)
GE GSHS9NGYBCSS Refrigerator Leaking and Not Cooling (Refrigerator & Freezer Repair)
by Wudman 1/13/2023 5:12:29 AM(UTC)
Refrigerator leaking after drain line is replaced. (Refrigerator & Freezer Repair)
by JustLooking72 9/22/2020 4:12:05 PM(UTC)
Refrigerator Leaking on the ice tray and front door (Refrigerator & Freezer Repair)
by RobertoS 8/2/2020 9:55:52 AM(UTC)
Whirlpool refrigerator leaks water (Refrigerator & Freezer Repair)
by timba 2/2/2020 2:09:49 PM(UTC)
Refrigerator Leaking inside (Refrigerator & Freezer Repair)
by iconracr 11/22/2019 8:15:56 AM(UTC)
GE Refrigerator leaks water (Refrigerator & Freezer Repair)
by low_lead 7/30/2015 2:04:37 PM(UTC)
GE refrigerator leaking water from bottom (Refrigerator & Freezer Repair)
by Raidem8 5/19/2015 10:50:03 AM(UTC)
Samsung Refrigerator leaking inside bottom of fridge area (Refrigerator & Freezer Repair)
by dpointer68 4/28/2014 7:03:27 PM(UTC)
Whirlpool refrigerator leaking water (Refrigerator & Freezer Repair)
by goosemasterkl 1/1/2014 8:14:42 AM(UTC)
Samsung refrigerator leaking water (Refrigerator & Freezer Repair)
by wendyjoe 5/27/2013 8:57:36 AM(UTC)
Samsung refrigerator leaking water on fresh food side (Refrigerator & Freezer Repair)
by TWAppliance 2/10/2013 11:16:13 AM(UTC)
Refrigerator leak (Refrigerator & Freezer Repair)
by gppaul 1/27/2013 5:08:52 PM(UTC)
Refrigerator leaking (Refrigerator & Freezer Repair)
by TomFrykman 1/22/2013 1:29:54 PM(UTC)
Refrigerator leaking on floor (Refrigerator & Freezer Repair)
by Qapla 12/31/2012 4:38:59 AM(UTC)
Kenmore refrigerator leaking (Refrigerator & Freezer Repair)
by rosesbjs 11/11/2012 11:11:53 PM(UTC)
