We have water on the floor (small puddle) at the left front corner of the refrigerator. We just replaced the ice maker but had the same leak before we did this. We have leveled the refrigerator but this did not stop the leaking. Any suggestions.Thanks.
Hello,
Very likely the cause of this water leak is a clogged/frozen drain in the freezer. The drain is located under the evaporator coils. Remove the rear cover in the freezer and defrost the drain using a hair dryer. Run some hot water through the drain using a turkey baster.
Pull the refrigerator out of the wall. Remove the cover and make sure the other end of the drain is clear as well.
