TomFrykman
#1 Posted : 12 years ago
TomFrykman
Hi, this refrigerator/freezer is leaking maybe a half-cup of water per day into the refrigerator from the (upper) freezer section.
I understand from several threads that this is likely due to a plugged drain. With this model unit, are the instructions generally to access the pan and drain from inside the freezer as other posts have suggested for other Whirlpool models?
There appears to be no access panel in the back other than at the base of the unit.
I really appreciate your help.
#2 Posted : 12 years ago
Hi Tom,
Remove the ice cube tray shelf. Remove the screws securing the freezer floor and pull the floor out. Remove the screws securing the rear panel and pull the panel out.
The drain hole is under the evaporator coils. You can use a hair dryer to defrost it and a turkey baster with hot water to make sure it goes through.
Here are the breakdown diagrams and Parts for Whirlpool ET19DKXFN00 Refrigerator - AppliancePartsPros.com
TomFrykman
#3 Posted : 12 years ago
TomFrykman
Thank you so much - you're the salt of the Earth. A mensch.
#4 Posted : 12 years ago
You are welcome. Thank you for your good words.
TomFrykman
#5 Posted : 12 years ago
TomFrykman
Hi, Gene - sorry to bother you, but another question because I can't tell from the parts schematic - how do I tell when I've cleared the drainage line? I don't know how long the tube is - I can only see down the drain maybe 3/4 inch. Sorry, never mind - I think I can see the pan in there - the drainage "tube" itself is maybe only a half-inch long itself, right?
#6 Posted : 12 years ago
Run some hot water through the drain using a turkey baster. Pull the refrigerator out of the wall. Remove the rear cover and you should see the other end of the drain hose. Make sure it's clean too.
TomFrykman
#7 Posted : 12 years ago
TomFrykman
Once again, thank you, thank you, thank you.
#8 Posted : 12 years ago
I'm glad to hear I could help you out. If there is anything else we can help you with, drop us a line.
GE GSHS9NGYBCSS Refrigerator Leaking and Not Cooling (Refrigerator & Freezer Repair)
by Wudman 2 years ago
Refrigerator leaking after drain line is replaced. (Refrigerator & Freezer Repair)
by JustLooking72 5 years ago
Refrigerator Leaking on the ice tray and front door (Refrigerator & Freezer Repair)
by RobertoS 5 years ago
Refrigerator Leaking inside (Refrigerator & Freezer Repair)
by iconracr 5 years ago
GE refrigerator leaking water from bottom (Refrigerator & Freezer Repair)
by Raidem8 10 years ago
Samsung Refrigerator leaking inside bottom of fridge area (Refrigerator & Freezer Repair)
by dpointer68 11 years ago
Whirlpool refrigerator leaking water (Refrigerator & Freezer Repair)
by goosemasterkl 11 years ago
Samsung refrigerator leaking water (Refrigerator & Freezer Repair)
by wendyjoe 12 years ago
Samsung refrigerator leaking water on fresh food side (Refrigerator & Freezer Repair)
by TWAppliance 12 years ago
Refrigerator leaking on floor (Refrigerator & Freezer Repair)
by Qapla 12 years ago
Kenmore refrigerator leaking (Refrigerator & Freezer Repair)
by rosesbjs 12 years ago
Refrigerator leaking water (Refrigerator & Freezer Repair)
by swiss54 13 years ago
Frigidaire Refrigerator leaking water (Refrigerator & Freezer Repair)
by GLORY S 13 years ago
Refrigerator leaking (Refrigerator & Freezer Repair)
by Barbara Lim 13 years ago
E-Wave Refrigerator leaking water (Refrigerator & Freezer Repair)
by Mmcr179 13 years ago
