TomFrykman
#1 Posted : Tuesday, January 22, 2013 1:29:54 PM(UTC)
TomFrykman
Hi, this refrigerator/freezer is leaking maybe a half-cup of water per day into the refrigerator from the (upper) freezer section.
I understand from several threads that this is likely due to a plugged drain. With this model unit, are the instructions generally to access the pan and drain from inside the freezer as other posts have suggested for other Whirlpool models?
There appears to be no access panel in the back other than at the base of the unit.
I really appreciate your help.
#2 Posted : Wednesday, January 23, 2013 1:02:58 PM(UTC)
Hi Tom,
Remove the ice cube tray shelf. Remove the screws securing the freezer floor and pull the floor out. Remove the screws securing the rear panel and pull the panel out.
The drain hole is under the evaporator coils. You can use a hair dryer to defrost it and a turkey baster with hot water to make sure it goes through.
Here are the breakdown diagrams and Parts for Whirlpool ET19DKXFN00 Refrigerator - AppliancePartsPros.com
TomFrykman
#3 Posted : Wednesday, January 23, 2013 1:25:01 PM(UTC)
TomFrykman
Thank you so much - you're the salt of the Earth. A mensch.
#4 Posted : Wednesday, January 23, 2013 8:53:45 PM(UTC)
You are welcome. Thank you for your good words.
TomFrykman
#5 Posted : Thursday, January 24, 2013 10:59:46 AM(UTC)
TomFrykman
Hi, Gene - sorry to bother you, but another question because I can't tell from the parts schematic - how do I tell when I've cleared the drainage line? I don't know how long the tube is - I can only see down the drain maybe 3/4 inch. Sorry, never mind - I think I can see the pan in there - the drainage "tube" itself is maybe only a half-inch long itself, right?
#6 Posted : Thursday, January 24, 2013 2:33:24 PM(UTC)
Run some hot water through the drain using a turkey baster. Pull the refrigerator out of the wall. Remove the rear cover and you should see the other end of the drain hose. Make sure it's clean too.
TomFrykman
#7 Posted : Friday, January 25, 2013 10:28:00 AM(UTC)
TomFrykman
Once again, thank you, thank you, thank you.
#8 Posted : Friday, January 25, 2013 1:58:55 PM(UTC)
I'm glad to hear I could help you out. If there is anything else we can help you with, drop us a line.
Guest (7)
GE GSHS9NGYBCSS Refrigerator Leaking and Not Cooling (Refrigerator & Freezer Repair)
by Wudman 1/13/2023 5:12:29 AM(UTC)
Refrigerator leaking after drain line is replaced. (Refrigerator & Freezer Repair)
by JustLooking72 9/22/2020 4:12:05 PM(UTC)
Refrigerator Leaking on the ice tray and front door (Refrigerator & Freezer Repair)
by RobertoS 8/2/2020 9:55:52 AM(UTC)
Refrigerator Leaking inside (Refrigerator & Freezer Repair)
by iconracr 11/22/2019 8:15:56 AM(UTC)
GE refrigerator leaking water from bottom (Refrigerator & Freezer Repair)
by Raidem8 5/19/2015 10:50:03 AM(UTC)
Samsung Refrigerator leaking inside bottom of fridge area (Refrigerator & Freezer Repair)
by dpointer68 4/28/2014 7:03:27 PM(UTC)
Whirlpool refrigerator leaking water (Refrigerator & Freezer Repair)
by goosemasterkl 1/1/2014 8:14:42 AM(UTC)
Samsung refrigerator leaking water (Refrigerator & Freezer Repair)
by wendyjoe 5/27/2013 8:57:36 AM(UTC)
Samsung refrigerator leaking water on fresh food side (Refrigerator & Freezer Repair)
by TWAppliance 2/10/2013 11:16:13 AM(UTC)
Refrigerator leaking on floor (Refrigerator & Freezer Repair)
by Qapla 12/31/2012 4:38:59 AM(UTC)
Kenmore refrigerator leaking (Refrigerator & Freezer Repair)
by rosesbjs 11/11/2012 11:11:53 PM(UTC)
Refrigerator leaking water (Refrigerator & Freezer Repair)
by swiss54 8/17/2012 5:19:43 PM(UTC)
Frigidaire Refrigerator leaking water (Refrigerator & Freezer Repair)
by GLORY S 5/16/2012 7:48:26 PM(UTC)
Refrigerator leaking (Refrigerator & Freezer Repair)
by Barbara Lim 1/16/2012 12:18:53 AM(UTC)
E-Wave Refrigerator leaking water (Refrigerator & Freezer Repair)
by Mmcr179 12/10/2011 6:02:29 AM(UTC)
