rb2400
#1 Posted : Tuesday, September 28, 2010 8:14:24 AM(UTC)
rb2400
This dryer blows air but not hot air. I purchased a heating element which looks like a long spring. My question is how do you replace it? I cant find any way to get the back off. Does it come off? Please tell me how to replace the heat element. Thank you!
sidfink43
#2 Posted : Friday, October 1, 2010 12:55:32 PM(UTC)
sidfink43
You get at this model from the front, but you first take off the small back service panel and release the belt from the pulley.
You then insert a screw driver in the gap between the top and the front near the edges to release the clips that hold the top on. It will flip up, allowing you to take out the screws that hold the front panel on. The drum will now lift out allowing you to get to the heating element.
You should know a couple of things.
1. It may not be the heating element that is your problem. Test it for continuity with a meter, and also test the thermostats which are just as likely your problem.
2. I would change out the rear bearing since it tends to fail on these machines.
3. You should thoroughly clean the inside, particularly the internal vent in the door and the machine itself.
4. If your belt looks worn, replace it too.
Good luck!
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
