8 Pages«<23456>»
Vegaswingrydr
#31 Posted : 15 years ago
Vegaswingrydr
There is a clip that holds the flap in the check valve. I removed the clip and the flap and did find a blockage that looked like it was part if the valve before I removed the flap......going to re install and re try
Vegaswingrydr
#32 Posted : 15 years ago
Vegaswingrydr
still draining slowly
#33 Posted : 15 years ago
Remove the check valve and make sure the hole in the pump plate is clear. See how water will go without the check valve.
resprod
#34 Posted : 15 years ago
resprod
Gene:
Is there another way to get to the check valve? I have tried every sort of way to get the wash impeller screw off but it is on tight. I am afraid of damaging the wash impeller as I try to get it off. I have a Whirlpool GU980CGQ3. The unit is 9 years old so I am not going to drop huge money into a fix since I am at the tale end of it's life.
#35 Posted : 15 years ago
You have to remove the drain hose from the check valve (#15 on the diagram) and unscrew the check valve. There are no other ways to check it. I did not understand why you went to the impeller. It has nothing to do with the drain problem.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU980SCGQ3 | AppliancePartsPros.com
resprod
#36 Posted : 15 years ago
resprod
Because I was going to from the top as I followed the diagram that the check valve shows it on. It was not until you sent the one with the front door assembly that I realized that it was right behind the access panel :o
Cleaned the valve and did a quick rinse. Drained fine. Thanks Gene!!
#37 Posted : 15 years ago
You are welcome. I'm glad you were able to fix it.
jgpetten
#38 Posted : 15 years ago
jgpetten
Gene:
Does this also apply to Whirlpool dishwasher Model DU945PWPT0? And in your response from above:
The second thing I would check is the check valve (#15 on the pump & motor break down diagram). Remove all water from the dishwasher, remove the bottom panel, disconnect the drain hose from the check valve and unscrew it.
are you saying unscrew the valve?
Thanks,
j
#39 Posted : 15 years ago
Originally Posted by: jgpetten Go to Quoted Post
Gene:
Thanks,
j
Yes. The clogged check valve is one of the most common cause for slow drain in such pumps.
Here are the breakdown diagrams and Pump and motor parts replacement parts for WHIRLPOOL DU945PWPT0 Undercounter Dishwasher | AppliancePartsPros.com
jgpetten
#40 Posted : 15 years ago
jgpetten
Thanks for the quick reply Gene! That did it it; just a tiny bedazzle bead from one of my daughter's toys.
thanks again!
j
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 3 years ago
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 3 years ago
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 9 years ago
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 12 years ago
New Whirlpool Dishwasher not draining (Dishwasher Repair)
by Maggy540 12 years ago
Whirlpool Dishwasher not draining entirely (Dishwasher Repair)
by johnwartjr 13 years ago
Whirlpool dishwasher not draining during wash cycle (Dishwasher Repair)
by krausjw 14 years ago
by miketran 14 years ago
by Tubhot2 14 years ago
by Cappsfam 15 years ago
Whirlpool Dishwasher Not Draining (Dishwasher Repair)
by fiorillo 15 years ago
8 Pages«<23456>»
