Tubhot2
#1 Posted : 14 years ago
Tubhot2
my dishwasher is leaving a couple inches of water in the bottom. just started since replacing garbage disposal.
what can I try to fix it?
whsydddy9
#2 Posted : 14 years ago
whsydddy9
This may sound silly....but did you knock out the plug that the dishwasher drain ties to? Or...could be the drain hose itself is plugged.
Tubhot2
#3 Posted : 14 years ago
Tubhot2
our whirlpool diswasher is not draining the last couple inches of water.
It just started after replacing our disposal.
Tubhot2
#4 Posted : 14 years ago
Tubhot2
not silly, where would I find the plug to check it?
Tubhot2
#5 Posted : 14 years ago
Tubhot2
I took off the hose and tried to blow in it but it did blow through.
whsydddy9
#6 Posted : 14 years ago
whsydddy9
the plug will be right inside of where you took the hose off to blow through it...
whsydddy9
#7 Posted : 14 years ago
whsydddy9
did that work for you ? (knocking out the garbage disposal plug)
you most likely won't be able to blow through the hose until the drain valve opens during a cycle...
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 3 years ago
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 3 years ago
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 9 years ago
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 12 years ago
New Whirlpool Dishwasher not draining (Dishwasher Repair)
by Maggy540 12 years ago
Whirlpool Dishwasher not draining entirely (Dishwasher Repair)
by johnwartjr 13 years ago
Whirlpool dishwasher not draining during wash cycle (Dishwasher Repair)
by krausjw 14 years ago
by miketran 14 years ago
by Cappsfam 15 years ago
Whirlpool Dishwasher Not Draining (Dishwasher Repair)
by fiorillo 15 years ago
by singh_kirpal 17 years ago
