8 Pages123>»
singh_kirpal
#1 Posted : Tuesday, January 15, 2008 4:31:44 PM(UTC)
singh_kirpal
The Dishwasher does not drain. If Cancel/Drain is pressed, the motor runs but it still does not drain.
#2 Posted : Wednesday, January 16, 2008 12:30:46 PM(UTC)
Hi Singh,
The first thing I would check is the air gap on top of the sink (if any).
Remove the cap and the top piece and check for any clog.
The second thing I would check is the check valve (#15 on the pump & motor break down diagram).
Remove all water from the dishwasher, remove the bottom panel, disconnect the drain hose from the check valve and unscrew it. Check for any clog.
Here are the break down diagrams for the Whirlpool dishwasher Model DU940PWKQ1 (basic model DU940PWK)
Good luck.
singh_kirpal
#3 Posted : Saturday, January 19, 2008 8:54:59 AM(UTC)
singh_kirpal
I appreciate your help, Gene. The Check Valve was clogged. I cleared it, and the draining is working now.
#4 Posted : Saturday, January 19, 2008 12:51:53 PM(UTC)
I'm glad you were able to fix it.
lttlnative
#5 Posted : Saturday, January 19, 2008 7:11:09 PM(UTC)
lttlnative
I cant figure this one out. Do you know why my new dishwasher wont drain either?
#6 Posted : Tuesday, January 22, 2008 12:18:41 PM(UTC)
In order to provide the most accurate advise I need the complete model number of the dishwasher and the most specific description of the problem.
chris1
#7 Posted : Wednesday, January 28, 2009 7:36:40 PM(UTC)
chris1
if you have a minute to give me some tips, it would be very helpful to me.
my friend just called me and said her dishwasher sprayed the water out through the drain thing on top of the sink. I'm guessing her main drain line is clogged, i'm heading that way tomorrow, i was just trying to be prepared before i arrive because i have never worked one dishwashers before. she has Whirlpool model DU 8400 XB1. If you can give me any tips it would be great.
Thanks ahead!
#8 Posted : Thursday, January 29, 2009 12:02:12 PM(UTC)
Check the hose from the air gap to the garbage disposal for a clog. If the garbage disposal has been replaced recently then most likely it was installed improperly. The new garbage disposal comes with the plastic plug in the dishwasher drain connection which has to be removed at time of installation.
PlanoRick
#9 Posted : Friday, February 20, 2009 6:41:12 AM(UTC)
PlanoRick
Gene,
I have a whirlpool gu1500xtlt3 dishwasher that also is not draining. The drain hose goes directly to the disposal connection. I can't tell if it is clogged but I blew into it and could here something from the bottom of the dishwasher / like bubbles.
Can you help me?
#10 Posted : Friday, February 20, 2009 1:22:00 PM(UTC)
PlanoRick,
Open the pump as described in one of our previous posts: http://forum.appliancepartspros...hirlpool-dishwasher.html and check the check valve (#5 on the diagram). Check the drain pump.
Here are the break down diagrams and the parts list for the Whirlpool dishwasher Model GU1500XTLT3
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
New Whirlpool Dishwasher not draining (Dishwasher Repair)
by Maggy540 12/26/2012 8:55:49 AM(UTC)
Whirlpool Dishwasher not draining entirely (Dishwasher Repair)
by johnwartjr 2/28/2012 6:33:16 AM(UTC)
Whirlpool dishwasher not draining during wash cycle (Dishwasher Repair)
by krausjw 6/5/2011 6:10:04 AM(UTC)
by miketran 1/27/2011 5:50:35 PM(UTC)
by Tubhot2 1/23/2011 9:53:57 AM(UTC)
by Cappsfam 3/21/2010 7:22:43 PM(UTC)
Whirlpool Dishwasher Not Draining (Dishwasher Repair)
by fiorillo 12/8/2009 5:29:52 AM(UTC)
8 Pages123>»
