jim3394
#1 Posted : Wednesday, June 2, 2010 2:29:00 PM(UTC)
jim3394
I have a GE profile that I believe has/had a bad defrost thermostat. I replaced the thermostat, but did not wire it in yet. I wanted to se it change state (ohms). My coils are iced over but the switch has not changed states yet. Does it need to be wired in to work correctly? Does it take a while to actuate? Any help would be appreciated. Defrost thermostat wr50x55. Thanks
#2 Posted : Thursday, June 3, 2010 6:31:31 AM(UTC)
Looking at the parts description it should close (0 ohms) at 35 degrees F and open (infinite ohms) at 55 degrees F.
[COLOR="Blue"]Does it need to be wired in to work correctly?[/COLOR]
No. I am assuming you are checking it with a meter.
[COLOR="Blue"]Does it take a while to actuate?[/COLOR]
Takes a little while so you will have to hold it on the ice till it gets down to freezing perhaps a couple minutes. Also do not touch the metal face when hold it on the ice.
jim3394
#3 Posted : Thursday, June 3, 2010 8:52:27 AM(UTC)
jim3394
Thanks for your help. I actually took it out and put it in a working freezer and it changed states. Installed and working correctly. Thanks for the help this site was extremely usefull.
Defrost Thermostat Stuck Closed? (Refrigerator & Freezer Repair)
by tim.widmann 6/3/2021 10:32:14 AM(UTC)
Want to give away a GE defrost thermostat (Refrigerator & Freezer Repair)
by Jorabi 6/27/2018 7:12:27 AM(UTC)
Defrost thermostat open/closed (Refrigerator & Freezer Repair)
by Jorabi 3/11/2018 5:25:55 PM(UTC)
refrigerator defrost thermostat (Refrigerator & Freezer Repair)
by joline 3/4/2017 2:15:53 PM(UTC)
Universal Defrost Thermostat (Refrigerator & Freezer Repair)
by rlogan 10/12/2016 1:06:39 PM(UTC)
Defrost thermostat rating (Refrigerator & Freezer Repair)
by RichNJ 9/3/2016 12:18:17 AM(UTC)
Replacing a 3 wire defrost thermostat (Refrigerator & Freezer Repair)
by arvetus 8/19/2016 6:53:56 PM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Replacing Defrost thermostat on (GE) Kenmore (Refrigerator & Freezer Repair)
by AUricle 7/14/2016 9:05:45 PM(UTC)
defrost thermostat not on Whirlpool diagram (Refrigerator & Freezer Repair)
by chrisyews 7/18/2015 6:22:00 AM(UTC)
Ice Build-up On Defrost Thermostat (Refrigerator & Freezer Repair)
by dantucson 7/31/2014 5:39:50 PM(UTC)
Defrost Thermostat DOA? (Refrigerator & Freezer Repair)
by spam 7/9/2014 3:27:06 PM(UTC)
How to test a defrost thermostat that has 4 wires (Refrigerator & Freezer Repair)
by appliance13 6/4/2014 3:20:27 PM(UTC)
Difference between defrost thermostats? (Refrigerator & Freezer Repair)
by Sockit 4/29/2014 8:10:13 AM(UTC)
Ice buildup on Defrost Thermostat (Refrigerator & Freezer Repair)
by russell@txwrights.com 1/20/2014 5:49:09 PM(UTC)
