Right side top element not heating. Looking to download service manual which I'm missing. Thanks
Any idea what to check since using 2 seperate switches to heat the rear and front two different areas of the common element, I thought they should be ok?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Any idea what to check on this problem? Both of the right side top elements both rear and front aren't heating at all. I thought since 2 seperate infinate switches and 2 seperate parts of the one common element that these parts might be ok?
If you look at the wiring diagram Page 4-48/
Left Hand Side Top it shows a 20 amp breaker (20 AMP)♦. also Right hand Side 1/3 Of The Way Down it shows a thermal cutout (RT CUTOUT) |
Originally Posted by: denman  If you look at the wiring diagram Page 4-48/
Left Hand Side Top it shows a 20 amp breaker (20 AMP)♦. also Right hand Side 1/3 Of The Way Down it shows a thermal cutout (RT CUTOUT) Thanks again. Since I'm troubleshooting this remotely for a friend (who can't find the breaker/thermal cutout) could you please tell me how to get access to these? I see per the parts diagram there are some breakers in the body area.
I do not know. All I can suggest is to check out the manual. |
Originally Posted by: denman  I do not know. All I can suggest is to check out the manual. Thanks again for your help. Found the problem It was a bad connector for the common lead for both receptacles in the RH receptacle.
I have the reverse of this problem. Yesterday my jenn air cooktop on the rightside would light both burners when the smaller (at rear) was turned on. The larger burner worked fine. Could this be the same issue? I didn't have time to switch my burner slide in's to see if the problem moved sides, but I will today.
Originally Posted by: mrbandit  I have the reverse of this problem. Yesterday my jenn air cooktop on the rightside would light both burners when the smaller (at rear) was turned on. The larger burner worked fine. Could this be the same issue? I didn't have time to switch my burner slide in's to see if the problem moved sides, but I will today. In order to provide most accurate advice we need the complete model number of the unit. Gene.
