I have a Frigidaire Electric Range (LGEF3043KFM) where the user is reporting there is uneven heat in the oven. I replaced the temperature probe. I put an analog thermometer in the center of the oven and watched the temperature rise. When set to 350F, the oven beeps ready at 275F on the analog meter. It takes another ~5 minutes for the analog to reach 350F. Is this normal? What would be the next step in troubleshooting. I noticed that the oven fan isn't spinning during the 350F pre-heat. Is this a problem? When is the fan supposed to spin? I checked the fan and have continuity through the fan (25 ohm) and the fan blades spin freely, so I don't think the fan is bad.
