2 Pages12>
sfairwa1
#1 Posted : Sunday, February 7, 2010 10:25:00 AM(UTC)
sfairwa1
Right side top element not heating. Looking to download service manual which I'm missing. Thanks
Any idea what to check since using 2 seperate switches to heat the rear and front two different areas of the common element, I thought they should be ok?
#2 Posted : Tuesday, February 9, 2010 1:01:36 AM(UTC)
sfairwa1
#3 Posted : Tuesday, February 9, 2010 7:26:35 AM(UTC)
sfairwa1
Perfect thanks for help.
sfairwa1
#4 Posted : Tuesday, February 9, 2010 10:37:23 AM(UTC)
sfairwa1
Any idea what to check on this problem? Both of the right side top elements both rear and front aren't heating at all. I thought since 2 seperate infinate switches and 2 seperate parts of the one common element that these parts might be ok?
#5 Posted : Tuesday, February 9, 2010 1:21:35 PM(UTC)
If you look at the wiring diagram Page 4-48/
Left Hand Side Top it shows a 20 amp breaker (20 AMP)♦.
also
Right hand Side 1/3 Of The Way Down it shows a thermal cutout (RT CUTOUT)
sfairwa1
#6 Posted : Tuesday, February 9, 2010 5:43:42 PM(UTC)
sfairwa1
also
Thanks again. Since I'm troubleshooting this remotely for a friend (who can't find the breaker/thermal cutout) could you please tell me how to get access to these? I see per the parts diagram there are some breakers in the body area.
#7 Posted : Thursday, February 11, 2010 3:20:32 AM(UTC)
I do not know.
All I can suggest is to check out the manual.
sfairwa1
#8 Posted : Thursday, February 11, 2010 8:42:15 PM(UTC)
sfairwa1
I do not know.
Thanks again for your help. Found the problem It was a bad connector for the common lead for both receptacles in the RH receptacle.
mrbandit
#9 Posted : Friday, February 26, 2010 8:42:58 AM(UTC)
mrbandit
I have the reverse of this problem. Yesterday my jenn air cooktop on the rightside would light both burners when the smaller (at rear) was turned on. The larger burner worked fine. Could this be the same issue? I didn't have time to switch my burner slide in's to see if the problem moved sides, but I will today.
#10 Posted : Friday, February 26, 2010 2:48:48 PM(UTC)
In order to provide most accurate advice we need the complete model number of the unit.
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 5/28/2022 9:09:03 AM(UTC)
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 2/27/2022 9:32:41 PM(UTC)
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 2/8/2022 6:38:17 AM(UTC)
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 7/12/2021 6:02:36 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
2 Pages12>
