Samsung model FTQ352IWUX range's SE error code has popped up after running a cleaning cycle. I reset manually with control panel and have also reset by disconnecting power. Very temperamental and reoccurs daily. A video I watched commented that the heat generated by the cleaning cycle could have caused a problem with the push controls in the range. How do I isolate the problem or should I replace control panel. Cost is of issue.
