MELLIOTT
#1 Posted : Tuesday, February 8, 2022 6:38:17 AM(UTC)
MELLIOTT
United States
Samsung model FTQ352IWUX range's SE error code has popped up after running a cleaning cycle. I reset manually with control panel and have also reset by disconnecting power. Very temperamental and reoccurs daily. A video I watched commented that the heat generated by the cleaning cycle could have caused a problem with the push controls in the range. How do I isolate the problem or should I replace control panel. Cost is of issue.
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
