carrol
#1 Posted : Saturday, August 18, 2007 5:34:26 AM(UTC)
carrol
Just recently my washer decided that two spins a cycle was too much. It will fill,wash and drain on first cycle, then fill and die on the rinse cycle. If I jank the machine back and forth, sometimes it will catch and begin draining and spinning--and sometimes it won't. Sometimes if I bail out most of the water it will catch and spin. Moving the knob around to different cycles has no effect--trying to turn the agitator by hand doesn't work. I am becoming very sore and brusied trying to wash laundry--any ideas that might help would be greatly appreciated.
#2 Posted : Saturday, August 18, 2007 1:23:38 PM(UTC)
Hi Carrol,
Sounds like the problem with your washer is a bad lid switch, but in order to help you better I need the complete model number of your washer. You can find it on top of the control panel.
carrol
#3 Posted : Monday, August 20, 2007 5:37:35 AM(UTC)
carrol
Gene,
The model number is VBXR1090D5CC. I purchased it inFeb.'05 and thought it would outlive me. Guess I must be dead--because it has died. We have foster children in our home and I NEED MY MACHINE. I know that on the top of the machine there is a magnetic white strip-and when I open or close the lid, I hear it click. How do I get the strip off?
Thanks for your input.
Carrol
Washer won't drain or spin (Washer Repair)
by garywool93 3/19/2015 9:40:02 AM(UTC)
Whirlpool top load washer won't drain or spin. (Washer Repair)
by Owie55 3/6/2015 1:21:47 PM(UTC)
GE Front Load washer won't drain or spin (Washer Repair)
by rmgaris 2/8/2014 8:15:28 PM(UTC)
GE Washer won't drain or spin (Washer Repair)
by JenNC 1/30/2014 12:52:31 PM(UTC)
roper washer won't drain or spin (Washer Repair)
by Mr.Stormcrow 1/23/2014 10:03:40 PM(UTC)
Kenmore washer won't drain or spin (Washer Repair)
by jpaw24 11/11/2013 6:40:40 AM(UTC)
Kenmore 70 series washer won't drain or spin (Washer Repair)
by ImSR 10/12/2013 8:49:49 AM(UTC)
by Karen.Smith 3/18/2013 12:01:38 PM(UTC)
KitchenAid Washer won't drain or spin (Washer Repair)
by MSUMOM 3/14/2013 7:25:53 PM(UTC)
GE Front Loading Washer Won't Drain or Spin (Washer Repair)
by gblotter 2/8/2013 8:23:32 PM(UTC)
by smyrnaref 8/5/2012 11:06:04 AM(UTC)
whirlpool washer won't drain or spin, lid switch OK (Washer Repair)
by trip2012 6/18/2012 7:38:38 AM(UTC)
by helpplease911 4/3/2012 12:16:26 PM(UTC)
washer won't drain or spin in gentle mode (Washer Repair)
by Frub 5/8/2011 7:17:11 AM(UTC)
by bethandgil 4/12/2011 5:05:27 PM(UTC)
