2 Pages12>
oogp1
#1 Posted : Wednesday, February 20, 2008 12:46:12 PM(UTC)
oogp1
Washer went unused for about eight months. I went to use it recently but it will not agitate. It fills up normally, but when it gets to the wash cycle it just makes a noise as if the motor is trying to turn but cannot. I tried turning the agitator by hand but it will not turn. I took off the agitator and give the spingle a gentle tap downwards but it still will not work. Please help. Ser# CM2702445 TYPE 157. Thank you.
#2 Posted : Thursday, February 21, 2008 11:45:31 AM(UTC)
Remove the cabinet according to these instructions and check the motor plug and wires.
Post your findings.
oogp1
#3 Posted : Friday, February 22, 2008 9:06:22 AM(UTC)
oogp1
Gene thank you for your response. I check the motor connections as you suggest , and all connections were tight. I completely disasembled the washer ( took off water pump, motor and gear case ). I found out that the Motor drive coupling is broken. I tried to turn the shaft that the couplin connects to after I removed the motor but it would only turn about 1/4 of the way around in both directions. I tried to take the gear case apart by taking all the bolts out and prying apart but was not successful. The shalf and gears turned, unlike before where it would not budge. Could the gears be bad or could it be bad breaks? If the gears are bad, how can I remedy this ? Mod. # RAK2751KQO. Thank you in advance.
oogp1
#4 Posted : Friday, February 22, 2008 1:04:59 PM(UTC)
If the gear case shaft is not turning in both ways - the gear case is bad and not the breaks.
I do not think it is a good idea to rebuild the gear case. There are no repair manuals for such job, hard to find parts and it's not worth money wise.
Replace the gear case and the coupling. Inspect the clutch and replace it too if it looks suspicious.
- The part number for the gear case is AP3096209
- The part number for the motor coupling is AP3961972
- The part number for the clutch is AP3094537
Here are the break down diagrams for the Roper washer Model RAK2751KQ0
oogp1
#5 Posted : Friday, February 22, 2008 1:22:51 PM(UTC)
oogp1
You have been a great help. Thank you. Will inspect and replace as needed. Thanks again.
oogp1
#6 Posted : Friday, February 22, 2008 1:39:19 PM(UTC)
Keep me updated, please.
oogp1
#7 Posted : Friday, February 22, 2008 4:35:42 PM(UTC)
oogp1
Again thanks so much. I have ordered the parts and am awaiting delivery.
Will update you when it is re-assembled.
oogp1
oogp1
#8 Posted : Wednesday, February 27, 2008 11:29:14 AM(UTC)
oogp1
Hello Gene ,I received the parts (gear case and coupling ) and have just completed instalation. Machine is working but there is a knocking noise when the machine is in the wash cycle. I cycles fine , but it makes a knocking noise about every half a second when washing. Could it be that that pan type disk that the clip washer sits in needed to be greesed ? Thanks again for your help and I awaits your response.
oogp1
#9 Posted : Thursday, February 28, 2008 10:36:17 AM(UTC)
Take it apart and reassemble to insure proper installation.
If it would not help, then the gears case is defective and has to be exchanged under the part warranty.
oogp1
#10 Posted : Tuesday, March 4, 2008 2:28:11 PM(UTC)
oogp1
Hello Gene, I took the machine apart and assembled it again but I have the same problem. I will have to return the gearcase for another one. Thanks again and I will let you know the outcome.
oogp1
Kenmore Washer will not agitate, but it will spin (Washer Repair)
by mjaymadson 8/2/2022 9:37:22 PM(UTC)
Estate washer will not agitate properly (Washer Repair)
by Guest 4/21/2022 8:19:49 AM(UTC)
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
kenmore washer will not agitate (Washer Repair)
by crawdadcreek 7/29/2015 10:07:27 AM(UTC)
by lizardking508 6/21/2015 12:00:22 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
Washer will not agitate (Washer Repair)
by jemiller33 11/25/2014 4:02:02 PM(UTC)
Washer will not agitate, or spin (Washer Repair)
by win809doo 5/19/2014 8:19:45 AM(UTC)
Washer will not agitate, spin, or drain (Washer Repair)
by nosinina 4/16/2014 8:42:37 AM(UTC)
Washer will not agitate, but does spin. (Washer Repair)
by Kas23 3/18/2014 2:50:05 PM(UTC)
washer will not agitate or spin (Washer Repair)
by CHERIE KING 2/27/2014 8:16:38 AM(UTC)
by dan mayville 12/23/2013 1:52:45 PM(UTC)
GE washer will not agitate but will rinse and spin (Washer Repair)
by gabemich 11/20/2013 8:35:25 AM(UTC)
Washer will not agitate spin or drain (Washer Repair)
by mdbk 11/6/2013 7:49:14 PM(UTC)
2 Pages12>
