2 Pages12>
Jim Hunt
#1 Posted : Saturday, July 25, 2009 1:31:44 PM(UTC)
Jim Hunt
How do I test the main board to see if it is bad. I have power to it. A new board cost $140 so I want to make sure the old one is bad before I buy a new one---Jim---
#2 Posted : Sunday, July 26, 2009 2:44:49 AM(UTC)
If it is just dead, you might have a blown thermal fuse, a white plastic part that plugs into the control board.
Jim Hunt
#3 Posted : Sunday, July 26, 2009 10:22:20 AM(UTC)
Jim Hunt
I cheaked the fuse its ok
#4 Posted : Sunday, July 26, 2009 11:50:02 AM(UTC)
Seems like you need a new board.
Jim Hunt
#5 Posted : Sunday, July 26, 2009 12:39:48 PM(UTC)
Jim Hunt
how do I tell if the board that has the control buttons is bad? ;)
#6 Posted : Sunday, July 26, 2009 3:19:10 PM(UTC)
I assumed the control module did nothing, power to it and no function, is this correct?
Jim Hunt
#7 Posted : Monday, July 27, 2009 4:22:05 PM(UTC)
Jim Hunt
Yes. That's right. The control panel has no power. It dose not work.right .
#8 Posted : Tuesday, July 28, 2009 2:13:17 AM(UTC)
So you measured voltage on the board side of the fuse, right.
Jim Hunt
#9 Posted : Tuesday, July 28, 2009 5:45:33 AM(UTC)
Jim Hunt
yes I have voltage to the board.
#10 Posted : Tuesday, July 28, 2009 6:10:07 AM(UTC)
There is no other item that will cause the board not to work, except a missing power ground. If you measure voltage to the board and the other lead to power ground on the board, usually a white wire= new board time.
Guest (11)
dish washer runs with doo open (Dishwasher Repair)
by Guest 4/17/2022 8:59:58 PM(UTC)
Dish washer not cleaning dishes KDTE204EPA1 (Dishwasher Repair)
by Guest 12/15/2021 7:24:01 AM(UTC)
correct orientation of plugs on ASKO D3122 anti flood microswitch. dish washer ? (Dishwasher Repair)
by turbo1600 8/20/2020 8:16:40 PM(UTC)
Whirlpool dish washer WDF110PABB2 Filling but not washing. (Dishwasher Repair)
by KG4MXV 6/15/2018 2:57:20 PM(UTC)
Kitchenaid dish washer leaking from below (Dishwasher Repair)
by chrysrobyn 12/19/2016 6:33:56 AM(UTC)
Dish washer stopped and want finish, all lights off (Dishwasher Repair)
by b.alford002@comcast.net 8/30/2015 11:17:11 AM(UTC)
How to replace motor bearings on Kitchen Aid KUDSO1FLSS1 dish washer (Dishwasher Repair)
by rajfixplumming 3/1/2014 10:33:52 AM(UTC)
Dish washer stops 14 Min in to cycle (Dishwasher Repair)
by Wayne_44 2/6/2014 4:55:37 PM(UTC)
Dish washer no lights on panel stopped mid cycle (Dishwasher Repair)
by 56Gomer 8/18/2013 6:34:28 AM(UTC)
by poloman 8/5/2013 9:38:22 AM(UTC)
by poloman 8/5/2013 9:34:27 AM(UTC)
Dish Washer (Dishwasher Repair)
by jobronie 7/25/2013 3:42:51 PM(UTC)
by everettwayne 6/19/2013 8:19:55 AM(UTC)
Dish washer won't dispense water. (Dishwasher Repair)
by Tom Loszchuk 4/2/2013 5:52:22 PM(UTC)
GE Dish Washer Stops midcycle (Dishwasher Repair)
by mwpresnell 2/8/2013 8:41:24 AM(UTC)
2 Pages12>
