All of a sudden the control lock came on and will not allow the panel to be unlocked so we can use the dishwasher, Sure need your advice and help
thanks
bob
Joined: 2/29/2008(UTC) Views messages in topic : 19,638
Your model number seems incomplete. Please check it. Sears/Kenmore numbers are usually 3 digits, a period and then an additional 8 digits.
Have you tried the unlock procedure in the user manual?
Have you tried removing poser from the unit for a couple minutes to see if it will reset? |
THIS FORUM IS DEAD!!!!!!! |
:( I have tried all suggested actions and those in the supplied manuel,
NO LUCK when I checked with a long time sears appliance person he said the board was bad, buying and having the old one fixed and the cost of a new one was almost the same , SO , we purchased a new washer. \
Thanks for your help, but like we know dead is dead,
poloman
