The dish washer stopped mid cycle. No lights on front panel. Thermal ohm checks good, both door switches good. Have 115v power to board. Looking for schematic.
Check behind bottom panel or main panel for tech sheet. Ohm test the float switch also if that isn't it and you said the therm fuse is good and both door switches...........if you have 120v at the main board and you didn't have any keypad issues before this happend i'd suspect the main board is bad. Here's your parts Control Panel parts for Whirlpool DU1055XTSD3 - AppliancePartsPros.com
Originally Posted by: HumboldtRepairMan  Check behind bottom panel or main panel for tech sheet. Ohm test the float switch also if that isn't it and you said the therm fuse is good and both door switches...........if you have 120v at the main board and you didn't have any keypad issues before this happend i'd suspect the main board is bad. Here's your parts Control Panel parts for Whirlpool DU1055XTSD3 - AppliancePartsPros.com Replaced the board, all is good. Thanks:)
