56Gomer
#1 Posted : 12 years ago
56Gomer
The dish washer stopped mid cycle. No lights on front panel. Thermal ohm checks good, both door switches good. Have 115v power to board. Looking for schematic.
HumboldtRepairMan
#2 Posted : 12 years ago
HumboldtRepairMan
Check behind bottom panel or main panel for tech sheet. Ohm test the float switch also if that isn't it and you said the therm fuse is good and both door switches...........if you have 120v at the main board and you didn't have any keypad issues before this happend i'd suspect the main board is bad.
Here's your parts
Control Panel parts for Whirlpool DU1055XTSD3 - AppliancePartsPros.com
56Gomer
#3 Posted : 12 years ago
56Gomer
Here's your parts
Replaced the board, all is good. Thanks:)
HumboldtRepairMan
#4 Posted : 12 years ago
HumboldtRepairMan
You're very welcome
