everettwayne
#1 Posted : Wednesday, June 19, 2013 8:19:55 AM(UTC)
everettwayne
dryer element for dishes will not heat.
#2 Posted : Friday, June 21, 2013 3:00:42 AM(UTC)
Parts for Whirlpool DU811SWPQ4 Dishwasher - AppliancePartsPros.com
See the attachment for the tech sheet
Remove power from the unit and check the heater for any physical damage.
If OK, check it with a meter. Should be around 20 to 30 ohms.
Check the thermal fuse for the heater, should be 0 ohms.
File Attachment(s):
DU811.pdf (215kb) downloaded 6 time(s).
dish washer runs with doo open (Dishwasher Repair)
by Guest 4/17/2022 8:59:58 PM(UTC)
Dish washer not cleaning dishes KDTE204EPA1 (Dishwasher Repair)
by Guest 12/15/2021 7:24:01 AM(UTC)
correct orientation of plugs on ASKO D3122 anti flood microswitch. dish washer ? (Dishwasher Repair)
by turbo1600 8/20/2020 8:16:40 PM(UTC)
Whirlpool dish washer WDF110PABB2 Filling but not washing. (Dishwasher Repair)
by KG4MXV 6/15/2018 2:57:20 PM(UTC)
Kitchenaid dish washer leaking from below (Dishwasher Repair)
by chrysrobyn 12/19/2016 6:33:56 AM(UTC)
Dish washer stopped and want finish, all lights off (Dishwasher Repair)
by b.alford002@comcast.net 8/30/2015 11:17:11 AM(UTC)
How to replace motor bearings on Kitchen Aid KUDSO1FLSS1 dish washer (Dishwasher Repair)
by rajfixplumming 3/1/2014 10:33:52 AM(UTC)
Dish washer stops 14 Min in to cycle (Dishwasher Repair)
by Wayne_44 2/6/2014 4:55:37 PM(UTC)
Dish washer no lights on panel stopped mid cycle (Dishwasher Repair)
by 56Gomer 8/18/2013 6:34:28 AM(UTC)
by poloman 8/5/2013 9:38:22 AM(UTC)
by poloman 8/5/2013 9:34:27 AM(UTC)
Dish Washer (Dishwasher Repair)
by jobronie 7/25/2013 3:42:51 PM(UTC)
Dish washer won't dispense water. (Dishwasher Repair)
by Tom Loszchuk 4/2/2013 5:52:22 PM(UTC)
GE Dish Washer Stops midcycle (Dishwasher Repair)
by mwpresnell 2/8/2013 8:41:24 AM(UTC)
drain on dish washer small leak (Dishwasher Repair)
by red&green 2/2/2013 10:43:44 AM(UTC)
