Kitchen Aid dishwasher is leaking from below while running. (WHOOSH WHOOSH drip WHOOSH WHOOSH drip drip ...) I unscrewed off the bottom fascia and I see the water dripping from a white piece of plastic on the right front. There are two wires going into this piece of plastic. I haven't been able to remove it, and I'm afraid I'm going to break it if it's screwed into place or I'm pulling the wrong direction. This white piece of plastic with two wires is directly below a tan round piece of plastic inside.
What do you think could be the problem? How can I remove this piece without breaking it?
Thanks for your help.
Groups: Expert
Originally Posted by: ThatGuy  I certainly am talking about 1 and 15. I tried to pull up on 15 but it felt like it stopped. If there is a retaining ring, should I just pull harder? Or is there a handy way to remove it? It stopped before I could really see under it. Thanks!!!
