I know this is an old thread and you may be long gone but anyway, here goes.
I am in the process of dealing with the same issue on a KEMC308 unit stays on. Keypad and display indicate unit is off and functioning normally dispite it heating on the inside. Fortunately for me I have a spare KEMC378 unit stored in my garage.
First I swapped the control panel and expected joy, no dice same problem.
Next I tore into the heating elements. The round element around the fan was the offending part. It was a little cruddy around the end where the plug connects, best I can figure is it was shorting to ground and feeding itself enough voltage to get and stay hot. I swapped that element with the one in the garage and BINGO back in action, good thing as tomorrow is Thanksgiving and I have got family coming over!
If you are still paying attention to this thread cbo2010, and you still have your old oven it may be worth your time to check the elements, and maybe spread some joy to the professionals that have already gave it their best.
Best Regards, t_bare
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I experienced a 2005 whirlpool oven staying stuck on. Even cutting power to it, did not fix it. When it had power again, it was still on. The off button would not work at all. I simultaneously depressed the start and off button until it chimed twice, I repeated this. It is now working properly. We will see for how long. At least I’m not buying a new oven today.
Rank: Guest
Straight dope message board, huns
