JDMACRAE
#1 Posted : Monday, June 22, 2009 6:30:20 PM(UTC)
JDMACRAE
Oven heats up (regular and convection), temp changes on indicator panel until set temp achieved, and beeps. However elements don't turn off. Lock indicator comes on when the oven gets hot enough. Temp sensor has been replaced, clock board, relay board and ribbon cable sent to a service depot but no fault found. Any ideas? JD
#2 Posted : Tuesday, June 23, 2009 2:15:19 AM(UTC)
Could not find any info using the given Model Number.
Does sound like a control board problem.
The reason I would lean towards the control board is that you say "elements do not turn off" cannot see two relays on the relay board sticking closed at the same time.
JDMACRAE
#3 Posted : Tuesday, June 23, 2009 8:32:33 AM(UTC)
JDMACRAE
Thanks - that's what it looks like - interesting that the cancel button shuts everything off. Unfortunatly, new control boards do not seem to be available unless someone out there knows a source. Will try resoldering the control board and relay board just in case. Hate to scrap the whole stove for this problem. JD
#4 Posted : Tuesday, June 23, 2009 9:04:34 AM(UTC)
Do a google, there are companies out there that will repair many of the older boards.
JDMACRAE
#5 Posted : Tuesday, June 23, 2009 9:15:54 AM(UTC)
JDMACRAE
Thanks - I'll give it a try. JD
Dan O.
#6 Posted : Tuesday, June 23, 2009 9:47:50 AM(UTC)
Dan O.
That's because it appears to be a Canadian model. The OP will likely need to contact a *local* Inglis or Canadian Whirlpool dealer or parts supplier to try to trace it.
JMO
Dan O.
www.Appliance411.ca
The Appliance Information Site
=D~~~~~~
JDMACRAE
#7 Posted : Tuesday, June 23, 2009 5:54:54 PM(UTC)
JDMACRAE
You are correct - a Canadian model. Clock board, relay baord, ribbon cable and sensor were all sent to a local repair depot but they couldn't find a fault. JD
#8 Posted : Wednesday, June 24, 2009 2:20:19 AM(UTC)
When you are preheating do the elements come on full (bright red).
Since cancel shuts them off you may have a short to the frame and they are running on 120 volts. This is a long shot but a possibility.
A wiring diagram would be a big help here.
May need a cross reference to the US unit.
I do not have this but perhaps Dan O does or knows of a way to get it.
JDMACRAE
#9 Posted : Wednesday, June 24, 2009 6:56:39 AM(UTC)
JDMACRAE
Thanks for the feedback - will check this evening. JD
Kitchen Aid duel fuel oven won't turn off (Model: KDRS407VSS04) (Oven Repair (including Ranges and Cooktops))
by Guest 2/5/2024 6:06:45 PM(UTC)
oven won't turn off (Oven Repair (including Ranges and Cooktops))
by ssmith11 8/27/2012 3:39:26 PM(UTC)
Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by cap424646 5/9/2012 5:53:54 PM(UTC)
Whirlpool Double Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by jforeman 5/8/2012 7:09:34 PM(UTC)
Whirlpool Double Oven Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by Bobmmm 2/7/2012 8:22:08 PM(UTC)
by oldschoolmc 1/4/2012 1:17:53 AM(UTC)
Kenmore oven won't turn off - recall (Oven Repair (including Ranges and Cooktops))
by genghiskhan 12/9/2011 11:02:28 AM(UTC)
by Debrab 6/5/2010 2:17:58 PM(UTC)
Kitchenaid Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Jane D 4/14/2010 7:01:04 PM(UTC)
by buster42 12/18/2009 4:07:01 AM(UTC)
by camorasch 12/7/2009 2:31:40 PM(UTC)
Set-in oven won't turn off. (Oven Repair (including Ranges and Cooktops))
by tdtk42 11/6/2009 7:29:02 AM(UTC)
by danieltravagliante 7/26/2009 10:52:14 AM(UTC)
Whirlpool oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Pat LaPorte 6/24/2009 8:45:36 PM(UTC)
by rg99 3/2/2009 3:22:59 PM(UTC)
