danieltravagliante
#1 Posted : Sunday, July 26, 2009 10:52:14 AM(UTC)
danieltravagliante
No matter what you set the temp. at it goes through the roof. The only way to shut it down is to kill the gas. Once it has cooled I can turn the gas back on. The range works fine, I'm assuming the thermostat.?. Is it easy to replace?
#2 Posted : Monday, July 27, 2009 11:28:26 AM(UTC)
Most likely the problem is a bad oven thermostat. If you are somehow handy this part is not too difficult to replace yourself. There are many screws to remove but do not be afraid of it. Unplug the range. You do not have to shut the gas off. Start with the top panel, then knobs and the front panel. Then burners and the burner box.
- The thermostat Part number: AP2623073
Here are the breakdown diagrams and Replacement parts for GE JGBC15GER6 | AppliancePartsPros.com
danieltravagliante
#3 Posted : Tuesday, July 28, 2009 2:11:23 PM(UTC)
danieltravagliante
Gene, Thanks for all the help. It was as easy to fix as you described.
#4 Posted : Tuesday, July 28, 2009 7:45:11 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Kitchen Aid duel fuel oven won't turn off (Model: KDRS407VSS04) (Oven Repair (including Ranges and Cooktops))
by Guest 2/5/2024 6:06:45 PM(UTC)
oven won't turn off (Oven Repair (including Ranges and Cooktops))
by ssmith11 8/27/2012 3:39:26 PM(UTC)
Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by cap424646 5/9/2012 5:53:54 PM(UTC)
Whirlpool Double Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by jforeman 5/8/2012 7:09:34 PM(UTC)
Whirlpool Double Oven Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by Bobmmm 2/7/2012 8:22:08 PM(UTC)
by oldschoolmc 1/4/2012 1:17:53 AM(UTC)
Kenmore oven won't turn off - recall (Oven Repair (including Ranges and Cooktops))
by genghiskhan 12/9/2011 11:02:28 AM(UTC)
by Debrab 6/5/2010 2:17:58 PM(UTC)
Kitchenaid Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Jane D 4/14/2010 7:01:04 PM(UTC)
by buster42 12/18/2009 4:07:01 AM(UTC)
by camorasch 12/7/2009 2:31:40 PM(UTC)
Set-in oven won't turn off. (Oven Repair (including Ranges and Cooktops))
by tdtk42 11/6/2009 7:29:02 AM(UTC)
Whirlpool oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Pat LaPorte 6/24/2009 8:45:36 PM(UTC)
by JDMACRAE 6/22/2009 6:30:20 PM(UTC)
by rg99 3/2/2009 3:22:59 PM(UTC)
