Bobmmm
#1 Posted : Tuesday, February 7, 2012 8:22:08 PM(UTC)
Bobmmm
A couple of weeks ago I got the error code E6F2. Called in the Whirlpool repair guy and he said the electronic control board was bad. Also said the part was not made any more. I got the board repaired, and installed the repaired board. Now everything seems to work except the oven won't turn off. I have to kill it with the breaker. Could the repair be faulty or is the problem now the keypad?
Bob:mad:
abadfish66
#2 Posted : Tuesday, February 7, 2012 8:26:13 PM(UTC)
abadfish66
I would guess the repair being faulty. The relay that controls the heat is stuck in the on position instead of cycling on and off.
Whirlpool Double Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by jforeman 5/8/2012 7:09:34 PM(UTC)
