4 Pages«<234
t_bare
#31 Posted : Wednesday, November 23, 2011 12:23:45 PM(UTC)
t_bare
I know this is an old thread and you may be long gone but anyway, here goes.
I am in the process of dealing with the same issue on a KEMC308 unit stays on. Keypad and display indicate unit is off and functioning normally dispite it heating on the inside. Fortunately for me I have a spare KEMC378 unit stored in my garage.
First I swapped the control panel and expected joy, no dice same problem.
Next I tore into the heating elements. The round element around the fan was the offending part. It was a little cruddy around the end where the plug connects, best I can figure is it was shorting to ground and feeding itself enough voltage to get and stay hot. I swapped that element with the one in the garage and BINGO back in action, good thing as tomorrow is Thanksgiving and I have got family coming over!
If you are still paying attention to this thread cbo2010, and you still have your old oven it may be worth your time to check the elements, and maybe spread some joy to the professionals that have already gave it their best.
Best Regards,
t_bare
Guest
#32 Posted : Monday, August 16, 2021 3:03:01 PM(UTC)
Guest
Rank: Guest
Groups:
United States
I experienced a 2005 whirlpool oven staying stuck on. Even cutting power to it, did not fix it. When it had power again, it was still on. The off button would not work at all. I simultaneously depressed the start and off button until it chimed twice, I repeated this. It is now working properly. We will see for how long. At least I’m not buying a new oven today.
Guest
#33 Posted : Tuesday, September 28, 2021 9:59:28 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Straight dope message board, huns
Kitchen Aid duel fuel oven won't turn off (Model: KDRS407VSS04) (Oven Repair (including Ranges and Cooktops))
by Guest 2/5/2024 6:06:45 PM(UTC)
oven won't turn off (Oven Repair (including Ranges and Cooktops))
by ssmith11 8/27/2012 3:39:26 PM(UTC)
Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by cap424646 5/9/2012 5:53:54 PM(UTC)
Whirlpool Double Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by jforeman 5/8/2012 7:09:34 PM(UTC)
Whirlpool Double Oven Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by Bobmmm 2/7/2012 8:22:08 PM(UTC)
by oldschoolmc 1/4/2012 1:17:53 AM(UTC)
Kenmore oven won't turn off - recall (Oven Repair (including Ranges and Cooktops))
by genghiskhan 12/9/2011 11:02:28 AM(UTC)
by Debrab 6/5/2010 2:17:58 PM(UTC)
Kitchenaid Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Jane D 4/14/2010 7:01:04 PM(UTC)
by buster42 12/18/2009 4:07:01 AM(UTC)
by camorasch 12/7/2009 2:31:40 PM(UTC)
Set-in oven won't turn off. (Oven Repair (including Ranges and Cooktops))
by tdtk42 11/6/2009 7:29:02 AM(UTC)
by danieltravagliante 7/26/2009 10:52:14 AM(UTC)
Whirlpool oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Pat LaPorte 6/24/2009 8:45:36 PM(UTC)
by JDMACRAE 6/22/2009 6:30:20 PM(UTC)
4 Pages«<234
