hi i have a kenmore washer that quit . it powers up for any cycle but it will not fill or move the drum. i can hear the drain pump works
Groups: Expert
you probably have a bad coupler... it's a small round piece between the motor and the transmission...
the motor doesn't even try to run could the micro cumputer be shot? thanks
