happytule
#1 Posted : Saturday, September 7, 2019 11:52:46 PM(UTC)
happytule
Hi, all-
I have a Duet Washer that is throwing an F02 error.
I cleaned the filter but I am still getting the error.
The machine is draining, at least sometimes.
I can hear the water going down the drain, in pulses, which I don't remember.
Does this sound like the drain pump?
If it is the pump, should I replace the entire pump or just the motor?
Best,
Chris
Edited by user Saturday, September 7, 2019 11:53:54 PM(UTC)  | Reason: Not specified
