Hi, all- I have a Duet Washer that is throwing an F02 error. I cleaned the filter but I am still getting the error. The machine is draining, at least sometimes. I can hear the water going down the drain, in pulses, which I don't remember. Does this sound like the drain pump? If it is the pump, should I replace the entire pump or just the motor? Best, Chris Edited by user Saturday, September 7, 2019 11:53:54 PM(UTC)
| Reason: Not specified
