johnep33333
#1 Posted : Wednesday, April 19, 2017 6:21:30 PM(UTC)
johnep33333
My whirlpool Ultimate Care II fills with water but wont spin. It makes a humming sound like its trying to spin. I checked the pump and it is clear. If I disconnect the motor I can spin it by hand and it starts spinning. All the connectors are in good shape. I replaced the timer switch and get the same problem. I bypassed the lid switch and same problem. I would think it had to be the motor but it will work if i give it a spin start by hand. Any help would be appreciated!!!!
manfred63
#2 Posted : Friday, April 21, 2017 9:57:36 AM(UTC)
manfred63
Sounds like either the pump is too hard to spin, such as the middle part that spins the impeller is stuck or frozen somewhat in place. OR, it could be a bad capacitor. Remove the water pump from the shaft, then see if it will spin normally. If it will, I would look closer at the pump, try spinning the impeller manually to see if it is easy to spin or very hard to spin. Replace pump if cant spin easily. If pump is good, test the capacitor, and replace it if it tests bad.
This video might help you out with that https://youtu.be/KXoxCVG_NBo
Ken's Appliance Repair
Whirlpool Ultimate Care II Washing Machine (Washer Repair)
by Guest 1/20/2023 8:42:21 AM(UTC)
Whirlpool Ultimate Care II LSQ8243HQ0 won't spin (Washer Repair)
by williamlee 4/7/2021 4:58:55 PM(UTC)
Whirlpool Ultimate Care II GSQ9364HQ0 (Washer Repair)
by skylightmissing 6/8/2020 3:51:54 PM(UTC)
Whirlpool Ultimate Care II, how do u remove Agitator Cam? (Washer Repair)
by DieselDavy 4/18/2020 5:07:51 AM(UTC)
Whirlpool Ultimate Care II won't spin consistently/maybe not draining? (Washer Repair)
by LauraSpillman 11/2/2016 12:42:13 PM(UTC)
Whirlpool Ultimate Care ii makes strange noise on spin cycle (Washer Repair)
by m042926 2/10/2015 5:38:41 PM(UTC)
Whirlpool Ultimate Care II cycle issues (Washer Repair)
by bisley45 1/25/2015 6:08:52 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
Belarus jajinnette 12/14/2014 10:09:44 AM(UTC)
Whirlpool Ultimate Care II problem (Washer Repair)
by uri 8/11/2014 7:25:44 AM(UTC)
Whirlpool Ultimate Care II help (Washer Repair)
by eelaroo2 4/8/2014 6:40:25 AM(UTC)
Whirlpool Ultimate Care II wont spin at the end of the cycle....motor humms. (Washer Repair)
Belarus tmv1962 12/19/2013 4:25:19 PM(UTC)
whirlpool ultimate care II washer help!! (Washer Repair)
by baseballmommy3 11/3/2013 1:08:54 AM(UTC)
Whirlpool Ultimate Care II Stuck (Washer Repair)
by thebeginning99 10/20/2013 7:28:45 AM(UTC)
whirlpool ultimate care II (Washer Repair)
by smith96 10/15/2013 9:40:30 AM(UTC)
Whirlpool Ultimate Care II Motor Diagnosis (Washer Repair)
by AndyWeg 9/23/2013 10:43:26 PM(UTC)
