thebeginning99
#1 Posted : Sunday, October 20, 2013 7:28:45 AM(UTC)
thebeginning99
I was doing a normal load in Super Capacity and the washer stopped working between wash and rinse.
I could smell a mild burning smell.
Turned the machine off and waited 30 mins, still not working. Emptied the washer and started to play with the timer. (Washer still full of water)
I checked the cold water valve its clean.
While playing with the knob I can get it to start to wash for quarter a second and then the agitator stops moving sounds like it is stuck. Other times it sounds like it wants to turn but is stuck on something.
What might be wrong?
thebeginning99
#2 Posted : Sunday, October 20, 2013 9:03:13 AM(UTC)
thebeginning99
I did some research on past threads and already tried bypassing the switch. Did not work. I can hear the motor turning to turn as before, but still does not work.
thebeginning99
#3 Posted : Sunday, October 20, 2013 9:16:17 AM(UTC)
thebeginning99
