I was doing a normal load in Super Capacity and the washer stopped working between wash and rinse. I could smell a mild burning smell.
Turned the machine off and waited 30 mins, still not working. Emptied the washer and started to play with the timer. (Washer still full of water) I checked the cold water valve its clean.
While playing with the knob I can get it to start to wash for quarter a second and then the agitator stops moving sounds like it is stuck. Other times it sounds like it wants to turn but is stuck on something.
What might be wrong?
I did some research on past threads and already tried bypassing the switch. Did not work. I can hear the motor turning to turn as before, but still does not work.
