smith96
#1 Posted : Tuesday, October 15, 2013 9:40:30 AM(UTC)
smith96
My whirlpool ultimate care II washer will fill but will not agitate thru cycle. I am wondering if it has to do with the lid switch and where it is. Thanks for your help in advance.
fairbank56
#2 Posted : Tuesday, October 15, 2013 9:42:24 AM(UTC)
fairbank56
Groups: Expert
Need your model number to determine that.
Eric
smith96
#3 Posted : Tuesday, October 15, 2013 9:51:39 AM(UTC)
smith96
Eric
i found 2 separate numbers:
LSQ9659PW2
CS1915513
smith96
#4 Posted : Tuesday, October 15, 2013 10:13:28 AM(UTC)
smith96
LSQ9659PW2
CS1915513
MODEL NUMBER: LSQ9659PW2
smith96
#5 Posted : Tuesday, October 15, 2013 10:24:48 AM(UTC)
smith96
MODEL LSQ9659PW2
fairbank56
#6 Posted : Tuesday, October 15, 2013 10:41:00 AM(UTC)
fairbank56
Groups: Expert
Yes, the lid switch on that model affects all motor operation, agitate, drain and spin. Open control panel, lid switch is on the left. Sometimes the hinge screws come loose and won't operate the switch. You can unplug the switch and jump out the two wires (gray and white) to see if washer will work.
Eric
smith96
#7 Posted : Tuesday, October 15, 2013 11:45:30 AM(UTC)
smith96
It turns out that the door hinge was loose. I tightened and closed the lid and it started agitating. Thanks.
revans322 @yahoo.com
#8 Posted : Tuesday, May 27, 2014 11:45:01 PM(UTC)
Are you referring on the left side in the rear of my whirlpool ultimate ll washer? Thank you
Whirlpool Ultimate Care II Washing Machine (Washer Repair)
by Guest 1/20/2023 8:42:21 AM(UTC)
Whirlpool Ultimate Care II LSQ8243HQ0 won't spin (Washer Repair)
by williamlee 4/7/2021 4:58:55 PM(UTC)
Whirlpool Ultimate Care II GSQ9364HQ0 (Washer Repair)
by skylightmissing 6/8/2020 3:51:54 PM(UTC)
Whirlpool Ultimate Care II, how do u remove Agitator Cam? (Washer Repair)
by DieselDavy 4/18/2020 5:07:51 AM(UTC)
whirlpool Ultimate Care II (Washer Repair)
by johnep33333 4/19/2017 6:21:30 PM(UTC)
Whirlpool Ultimate Care II won't spin consistently/maybe not draining? (Washer Repair)
by LauraSpillman 11/2/2016 12:42:13 PM(UTC)
Whirlpool Ultimate Care ii makes strange noise on spin cycle (Washer Repair)
by m042926 2/10/2015 5:38:41 PM(UTC)
Whirlpool Ultimate Care II cycle issues (Washer Repair)
by bisley45 1/25/2015 6:08:52 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Whirlpool Ultimate Care II problem (Washer Repair)
by uri 8/11/2014 7:25:44 AM(UTC)
Whirlpool Ultimate Care II help (Washer Repair)
by eelaroo2 4/8/2014 6:40:25 AM(UTC)
Whirlpool Ultimate Care II wont spin at the end of the cycle....motor humms. (Washer Repair)
by tmv1962 12/19/2013 4:25:19 PM(UTC)
whirlpool ultimate care II washer help!! (Washer Repair)
by baseballmommy3 11/3/2013 1:08:54 AM(UTC)
Whirlpool Ultimate Care II Stuck (Washer Repair)
by thebeginning99 10/20/2013 7:28:45 AM(UTC)
Whirlpool Ultimate Care II Motor Diagnosis (Washer Repair)
by AndyWeg 9/23/2013 10:43:26 PM(UTC)
